I am using a Productivity 3000 PLC, I will likely replace it with the newer P2000
I am looking at installing 15-20 Thermisitors throughout my house to track the temp change throughout the day, etc.
Thermisitors are nice since they do not require special wire and you can get the raw sensors from Amazon/ebay for under $2 each.
I am in a single story home so getting access to each room is not a problem.
I think I can push the sensor (about the size of a small LED) out by the light fixture or fan.
If that does not work I may be able to drill a small hole and caulk it in the attic.
I am going to mount the PLC in the garage.
Eventually I will have the PLC control my Heating/AC accepting most control from OH but adding ladder logic to perform sanity and safety checks.
Well I got thinking about it and since my PLC has the word swap option I was able to re-write the tags I wanted to read from OH to the PLC over MODBUS with the word swap disabled and then OH had no problems reading the word swapped copy…
But it still would be a useful feature if the binding had that option…
SO I guess the only questions that remain are…
How do I figure out who maintains that binding?
What is the best way do make a enhancement request?
(If the best way is to just do it then that will bring up a host of other questions!!)
I’m more than happy to make the changes if they will work there way into the main distribution and eventually OH2
