I`m running OH2 und Win7 with the Modbus 2.4 Binding
TSP slave is installed and online
Poller is installed and online
connectet to Slave
Poll Intervall: 500
Startadress: 0
Length: 120
Type: Coil o. Do
Data is installed and online
connected to poller,
Read adress: 0
Read value type: bit
Write Type: coil or. Do
Write value Type: bit
Read transform: default
Write address: 512
Write transform: default
Write multiple even with single register --> on
all done in PaperUI
In VSC .items created from channel
.items
Switch WagoH1WohnenModbusData_Switch4 âHaus1AmpTerasseâ (gLabTest) {channel=âmodbus:data:f6662cad:switchâ}
Im using Wago 750-881 with 50 Do - in the configuration above the .item Switch is only on the first Do1
Adress: write 0.0 - status 512.0 reacting
My Problem is:
How to adress the next adresses
Adress: write 0.1 - status 512.1 , write 0.1 - status 512.1 , write 0.2 - status 512.2 , write 0.3 - status 512.3
I tried div. channel Mods z.b. {channel=âmodbus:data:f6662cad:coil:D2:switchâ} without success
Do i have to install multible Data things + coressponding items ???
I would like to have only one data .thing an than al list of 80 .items (Switches) to control the Do´s
Yes. The flexibility of the modbus binding, that allows you to do things like read and write to different addresses or even different types for the same âthingâ, comes at the cost of a quite manual configuration process.
âToo badâ Iâm afraid
You only have to do it once.
Some user prefer to configure with a xxx.things file instead of PaperUI, as you can see everything at once and assign sensible channel names.
Either/or, donât try to mix methods.
