Hey there,
I’m trying to get a value out of my SMA Sunny Boy 3.0 via Modbus. This works fine for one device, but the same configuration for another device has a strange behavior. Sometimes it shows the correct value, but the it switches to a value in binary code (e.g. 256, 512, 1024, 2048). When I use a Windows tool to read out the modbus register it always shows the correct value. Has anyone a clue why the Binding sometimes overrides to correct value with (256, 512 or 1024 …)? Maybe @mrbig?
Trace log:
2020-07-27 19:19:31.035 [DEBUG] [rt.modbus.internal.ModbusManagerImpl] - Executing scheduled (5000ms) poll task BasicPollTask@38d21bdc[request=ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502],resultCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f,failureCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f]. Current millis: 1595870371035
2020-07-27 19:19:31.038 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Starting new operation with task BasicPollTask@38d21bdc[request=ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502],resultCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f,failureCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f]. Trying to get connection [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.040 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Executing task BasicPollTask@38d21bdc[request=ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502],resultCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f,failureCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f] (oneOff=false)! Waiting for connection. Idle connections for this endpoint: 0, and active 0 [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.042 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Created connection TCPMasterConnection@7d1d82c3[socket=<null>] for endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502]
2020-07-27 19:19:31.060 [DEBUG] [wimpi.modbus.net.TCPMasterConnection] - connect()
2020-07-27 19:19:31.062 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Waited 0ms (interTransactionDelayMillis 60ms) before giving returning connection TCPMasterConnection@7d1d82c3[socket=Socket[addr=/192.168.6.115,port=502,localport=39716]] for endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502], to ensure delay between transactions.
2020-07-27 19:19:31.067 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - borrowing connection (got Optional[TCPMasterConnection@7d1d82c3[socket=Socket[addr=/192.168.6.115,port=502,localport=39716]]]) for endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502] took 24 ms
2020-07-27 19:19:31.073 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Executing task BasicPollTask@38d21bdc[request=ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502],resultCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f,failureCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f] (oneOff=false)! Connection received in 31 ms [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.075 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Operation with task BasicPollTask@38d21bdc[request=ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502],resultCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f,failureCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f]. Got a connection successfully [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.092 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.093 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Ensuring that enough time passes before retrying again. Sleeping if necessary [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.095 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Sleep ended, slept 0 [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.096 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Going execute transaction with request request (FC=READ_MULTIPLE_REGISTERS): 00 00 00 00 00 06 03 03 78 37 00 02 [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.101 [TRACE] [wimpi.modbus.io.ModbusTCPTransaction] - Sending request with transaction ID 7: net.wimpi.modbus.msg.ReadMultipleRegistersRequest@6afa22b4
2020-07-27 19:19:31.241 [TRACE] [wimpi.modbus.io.ModbusTCPTransaction] - Received response with transaction ID 7
2020-07-27 19:19:31.243 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Response for read request (FC=3, transaction ID=7): 00 07 00 00 00 07 03 03 04 00 00 01 00 [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.245 [TRACE] [modbus.internal.ModbusLibraryWrapper] - Calling read response callback org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f for request ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3]. Response was net.wimpi.modbus.msg.ReadMultipleRegistersResponse@5659d0d7
2020-07-27 19:19:31.247 [DEBUG] [bus.handler.ModbusPollerThingHandler] - Thing modbus:poller:sb3000-haus:sb3000-haus_input1 received response PollResult(failure=null)
2020-07-27 19:19:31.250 [TRACE] [ernal.handler.ModbusDataThingHandler] - Channel number will be updated to '256' (type DecimalType). Input data: number value 256 (value type 'int32' taken into account) and bool value true. Transformation: <identity>
2020-07-27 19:19:31.262 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:sb3000-haus:sb3000-haus_input1:sb3000-haus_power channels updated: {modbus:data:sb3000-haus:sb3000-haus_input1:sb3000-haus_power:number=256}. readValueType=int32, readIndex=Optional[30775], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 256 and boolValue=true. Registers ModbusRegisterArrayImpl(00 00 01 00) for request ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3]
2020-07-27 19:19:31.266 [TRACE] [modbus.internal.ModbusLibraryWrapper] - Called read response callback org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f for request ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3]. Response was net.wimpi.modbus.msg.ReadMultipleRegistersResponse@5659d0d7
2020-07-27 19:19:31.270 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Validating endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502] connection TCPMasterConnection@7d1d82c3[socket=Socket[addr=/192.168.6.115,port=502,localport=39716]] -> true
2020-07-27 19:19:31.273 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - Passivating connection TCPMasterConnection@7d1d82c3[socket=Socket[addr=/192.168.6.115,port=502,localport=39716]] for endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502]...
2020-07-27 19:19:31.278 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - (passivate) Connection TCPMasterConnection@7d1d82c3[socket=Socket[addr=/192.168.6.115,port=502,localport=39716]] (endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502]) age 215ms is over the reconnectAfterMillis=0ms limit or has been connection time (1595870371062) is after the "disconnectBeforeConnectedMillis"=-1 -> disconnecting.
2020-07-27 19:19:31.281 [TRACE] [ing.ModbusSlaveConnectionFactoryImpl] - ...Passivated connection TCPMasterConnection@7d1d82c3[socket=Socket[addr=/192.168.6.115,port=502,localport=39716]] for endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502]
2020-07-27 19:19:31.286 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - returned connection to pool for endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502]
2020-07-27 19:19:31.289 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - returning connection for endpoint ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502] took 18 ms
2020-07-27 19:19:31.292 [TRACE] [rt.modbus.internal.ModbusManagerImpl] - Connection was returned to the pool, ending operation [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.295 [DEBUG] [rt.modbus.internal.ModbusManagerImpl] - Modbus operation ended, timing info: {total: 258 ms, connection: 53, transaction=143, callback=25} [operation ID f929ce8a-e019-48d9-9f60-f8c19e40b1aa]
2020-07-27 19:19:31.300 [DEBUG] [rt.modbus.internal.ModbusManagerImpl] - Execution of scheduled (5000ms) poll task BasicPollTask@38d21bdc[request=ModbusPollerThingHandler.ModbusPollerReadRequest@1c5c5c8d[slaveId=3,functionCode=READ_MULTIPLE_REGISTERS,start=30775,length=2,maxTries=3],endpoint=ModbusTCPSlaveEndpoint@541237e3[address=192.168.6.115,port=502],resultCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f,failureCallback=org.openhab.binding.modbus.handler.ModbusPollerThingHandler$ReadCallbackDelegator@56e9d40f] finished at 1595870371299. Was started at millis: 1595870371035 (=duration of 264 millis)
Thing:
Bridge modbus:tcp:sb3000-haus [ host="192.168.6.115", port=502, id=3 ] {
Bridge poller sb3000-haus_input1 [ start=30775, length=2, refresh=5000, type="holding" ] {
Thing data sb3000-haus_power [ readStart="30775", readValueType="int32" ]
Item:
Number SB3000_power "SB3.0 Haus Leistung [%d W]" <energy> { channel="modbus:data:sb3000-haus:sb3000-haus_input1:sb3000-haus_power:number" }
Sitemap:
Text item=SB3000_power
Event log:
2020-07-27 19:29:45.480 [vent.ItemStateChangedEvent] - SB3000_power changed from 278 to 256
2020-07-27 19:29:55.673 [vent.ItemStateChangedEvent] - SB3000_power changed from 256 to 279
2020-07-27 19:30:00.796 [vent.ItemStateChangedEvent] - SB3000_power changed from 279 to 256
2020-07-27 19:30:05.890 [vent.ItemStateChangedEvent] - SB3000_power changed from 256 to 270
2020-07-27 19:30:10.997 [vent.ItemStateChangedEvent] - SB3000_power changed from 270 to 256
2020-07-27 19:30:26.315 [vent.ItemStateChangedEvent] - SB3000_power changed from 256 to 276
2020-07-27 19:30:31.420 [vent.ItemStateChangedEvent] - SB3000_power changed from 276 to 256
2020-07-27 19:31:37.822 [vent.ItemStateChangedEvent] - SB3000_power changed from 256 to 265
2020-07-27 19:31:42.926 [vent.ItemStateChangedEvent] - SB3000_power changed from 265 to 256
2020-07-27 19:31:53.128 [vent.ItemStateChangedEvent] - SB3000_power changed from 256 to 265
2020-07-27 19:31:58.235 [vent.ItemStateChangedEvent] - SB3000_power changed from 265 to 264
2020-07-27 19:32:03.333 [vent.ItemStateChangedEvent] - SB3000_power changed from 264 to 256
