Hi
I want a widget to modify from habpanel the hours, minutes and seconds.
Can you help me?
What time do you want to set? There is no direct widget to chose time or date, but of course you could build some items to store time (and date) as separate numbers, which then could be changed through setpoint or even a slider.
I have not experience of html.
I want to set from the habpanel an hours to go up the shutter automatically.
Really? There are much better ways to automate roller shutters (Astro Binding - setup earliest, latest time to open/close the roller shutter, setup an offset, let the roller shutters open & close depending on sunrise/sunset.)
If you really want it like in the last century simply define four Number items:
Group Shuttertime
Number ShutterUpMin "Minute [%d]" (Shuttertime)
Number ShutterUpHour "Hour [%d]" (Shuttertime)
Number ShutterDownMin "Minute [%d]" (Shuttertime)
Number ShutterDownHour "Hour [%d]" (Shuttertime)
Then setup four Widgets to change the Items (step 1, minimum 0, maximum 23 or 59 depending on the item)
Setup a rule:
// define all global var or val at the beginning of the file
var Timer tShutterOpen = null
var Timer tShutterClose = null
rule "set shutter timers"
Time is midnight or
Member of Shuttertime changed
if(Shuttertime.members.filter[m | m.state ! (instanceof Number)].size > 0) {
logWarn("shutterTimer","Some item is not of type Number!")
return;
val nUp = (ShutterUpMin.state as Number) + (ShutterUpHour.state as Number) * 60
val nDown = (ShutterDownMin.state as Number) + (ShutterDownHour.state as Number) * 60
if(nUp > now.getMinuteOfDay) {
tShutterOpen?.cancel
tShutterOpen = createTimer(now.withTimeAtStartOfDay.plusMinutes(nUp), [ |
Shutters.sendCommand(UP)
if(nDown > now.getMinuteOfDay) {
tShutterClose?.cancel
tShutterClose = createTimer(now.withTimeAtStartOfDay.plusMinutes(nDown), [ |
Shutters.sendCommand(DOWN)
Theory of working:
- The rule is triggered at midnight and if one of the items changed its status.
- as a first step, the rule checks if all time items are set to a number value. If not, the rule is cancelled immediately.
- Second step is to calculate the chosen time (in Minutes) for up and down.
- Third step is to calculate if up time has passed for today.
- Fourth step ist to set a timer according to the calculated time. As there is a chance that there already was a running timer, we first cancel the timer, if scheduled (tShutterOpen?.cancel)
- Do the steps three and four for the down command.
EDIT: Changed rule code (added missing brackets)
I’m studing the rule
but if i run it i have
2019-03-21 14:18:51.771 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘settare_orario - Copia.rules’ has errors, therefore ignoring it: [6,49]: no viable alternative at input ‘instanceof’
The error is here
if(Shuttertime.members.filter[m | m.state ! instanceof Number].size > 0) {
return;
I think the “!” is the error. Is it true?
I have a question:
What kind of elements i must set for i 4 shuttertime elements?
i report you the situation
the items are
I modified the code:
Time is midnight or
if(Shuttertime.members.filter[m | m.state instanceof Number].size > 0) {
return;
LivingRoom_Light2.sendCommand(ON)
LivingRoom_Light1.sendCommand(OFF)
The panel is
The problem is that when i set the value so
i have this
2019-03-21 16:14:01.833 [ome.event.ItemCommandEvent] - Item ‘ShutterUpHour’ received command 16
2019-03-21 16:14:02.448 [ome.event.ItemCommandEvent] - Item ‘ShutterUpMin’ received command 25
2019-03-21 16:14:02.478 [vent.ItemStateChangedEvent] - ShutterUpMin changed from 21 to 25
2019-03-21 16:14:02.500 [WARN ] [.smarthome.model.script.shutterTimer] - Some item is not of type Number!
2019-03-21 16:14:03.106 [ome.event.ItemCommandEvent] - Item ‘ShutterDownHour’ received command 20
2019-03-21 16:14:03.124 [vent.ItemStateChangedEvent] - ShutterDownHour changed from 1 to 20
2019-03-21 16:14:03.139 [WARN ] [.smarthome.model.script.shutterTimer] - Some item is not of type Number!
2019-03-21 16:14:03.838 [ome.event.ItemCommandEvent] - Item ‘ShutterDownMin’ received command 0
2019-03-21 16:14:03.850 [vent.ItemStateChangedEvent] - ShutterDownMin changed from 1 to 0
2019-03-21 16:14:03.877 [WARN ] [.smarthome.model.script.shutterTimer] - Some item is not of type Number!
NOTE: the items ShutterDownMin, ShutterDownHour, ShutterUpMin, ShutterUpHour of course are not linked with sonoff but i use it only to determine the time to turn on or off.
The items linked with sonoff are LivingRoom_Light1 e LivingRoom_Light2
Please change the line to
the !
is the boolean NOT. Sorry for forgetting the brackets…
this is the new error
2019-03-21 18:20:37.613 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model ‘settare_orario2.rules’
2019-03-21 18:20:37.621 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘settare_orario2.rules’ is either empty or cannot be parsed correctly!
2019-03-21 18:20:38.770 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model ‘settare_orario2.rules’ has errors, therefore ignoring it: [6,50]: no viable alternative at input ‘instanceof’
[6,67]: extraneous input ‘)’ expecting ‘]’
The problem is alway on “instanceof number”
Aaaaaargh… sorry…
if(Shuttertime.members.filter[m | !(m.state instanceof Number)].size > 0) {
Well, shift work and early service…
I try again
Now i have
2019-03-21 18:35:44.014 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘set shutter timers’: An error occurred during the script execution: Could not invoke method: org.joda.time.DateTime.plusMinutes(int) on instance: 2019-03-21T00:00:00.000+01:100:
I’m not sure that my items are good.
look my situation:
this is how i set the four widgets:
Can you advise me how i have to modify the elements of the panel?
Look at ShutterUpHour
, You accidentally typed ShutterUPHour
Time for some additional logging:
Time is midnight or
Shuttertime.members.filter[m | !(m.state instanceof Number)].forEach[ m|
logWarn("shutterTimer","{} : {}",m.name,m.state.toString)]
return;
Shuttertime.members.forEach[ m|
logInfo("shutterTimer","{} : {}",m.name,m.state.toString)]
logInfo("shutterTimer","nUp: {}; nDown: {}",nUp,nDown)
now i have this
2019-03-21 19:55:06.756 [INFO ] [.smarthome.model.script.shutterTimer] - ShutterUpMin : 10
2019-03-21 19:55:06.762 [INFO ] [.smarthome.model.script.shutterTimer] - ShutterUpHour : 20
2019-03-21 19:55:06.767 [INFO ] [.smarthome.model.script.shutterTimer] - ShutterDownMin : 4
2019-03-21 19:55:06.771 [INFO ] [.smarthome.model.script.shutterTimer] - ShutterDownHour : 3
2019-03-21 19:55:06.781 [INFO ] [.smarthome.model.script.shutterTimer] - nUp: 1210; nDown: 184
2019-03-21 19:55:06.791 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule ‘set shutter timers’: An error occurred during the script execution: Could not invoke method: org.joda.time.DateTime.plusMinutes(int) on instance: 2019-03-21T00:00:00.000+01:00
