Hi!
Thanks a lot for your analysis!
This was really a good step forward even though the solution is not obvious
I made another log with the comment settings enabled. For whatever reason it lasted longer this time.
The error now looks a bit different. It seems to recover first, but then stops polling again.
Below you can find the log!
Further I resetted the USR-M511 afterwards, but this did not help on the binding side. It does not start polling again.
I was wondering why the binding stops polling?
Shouldn’t it be robust enough to survive it?
Best regards,
Matthias
2020-03-09 09:03:30.177 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:AnlagenWerte2 received registers RegisterArrayWrappingInputRegister(00 0f ff ff)
for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@3818a30f[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=1000,length=2,maxTries=5]
2020-03-09 09:03:30.181 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:AnlagenWerte2:cAussenTemperatur channels updated: {modbus:data:Heizungsanlage:Anlag
enWerte2:cAussenTemperatur:number=7.5}. readValueType=int16, readIndex=Optional[1000], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 15 and boolValue=true. Registers RegisterArrayWr
appingInputRegister(00 0f ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@3818a30f[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=1000,length=2,maxTries=5]
2020-03-09 09:03:33.425 [ERROR] [wimpi.modbus.io.ModbusTCPTransaction] - execute try 1/1 error: I/O exception: SocketTimeoutException Read timed out. Request: net.wimpi.modbus.msg.ReadInput
RegistersRequest@78278b80 (unit id 1 & transaction 25084). Address: /192.168.179.132:502
2020-03-09 09:03:33.426 [ERROR] [wimpi.modbus.io.ModbusTCPTransaction] - execute reached max tries 1, throwing last error: I/O exception: SocketTimeoutException Read timed out. Request: net
.wimpi.modbus.msg.ReadInputRegistersRequest@78278b80 (unit id 1 & transaction 25084). Address: /192.168.179.132:502
2020-03-09 09:03:33.426 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 5 failed when executing request (ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@56dda554[slaveId=
1,functionCode=READ_INPUT_REGISTERS,start=1030,length=65,maxTries=5]). Will try again soon. Error was I/O error, so reseting the connection. Error details: net.wimpi.modbus.ModbusIOExceptio
n I/O exception: SocketTimeoutException Read timed out [operation ID 5b9d50db-dfd8-44a2-b9e3-70ab4cd2f594]
2020-03-09 09:03:36.637 [ERROR] [wimpi.modbus.io.ModbusTCPTransaction] - execute try 1/1 error: I/O exception: SocketTimeoutException Read timed out. Request: net.wimpi.modbus.msg.ReadInput
RegistersRequest@4ac0d71c (unit id 1 & transaction 25085). Address: /192.168.179.132:502
2020-03-09 09:03:36.637 [ERROR] [wimpi.modbus.io.ModbusTCPTransaction] - execute reached max tries 1, throwing last error: I/O exception: SocketTimeoutException Read timed out. Request: net
.wimpi.modbus.msg.ReadInputRegistersRequest@4ac0d71c (unit id 1 & transaction 25085). Address: /192.168.179.132:502
2020-03-09 09:03:36.638 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 2 out of 5 failed when executing request (ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@56dda554[slaveId=
2020-03-09 09:03:36.846 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:HeizkreisWerte received registers RegisterArrayWrappingInputRegister(00 45 00 5c
00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff)
for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@56dda554[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=1030,length=65,maxTries=5]
2020-03-09 09:03:36.849 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisWerte:cHeizkreisWandVorlaufIstTemperatur channels updated: {modbus:data:He
izungsanlage:HeizkreisWerte:cHeizkreisWandVorlaufIstTemperatur:number=34.5}. readValueType=int16, readIndex=Optional[1030], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 69 and bool
Value=true. Registers RegisterArrayWrappingInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@56dda554[slaveId=1,functionCode=READ_INPUT_REGISTERS,s
2020-03-09 09:03:36.852 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisWerte:cHeizkreisWandVorlaufSollTemperatur channels updated: {modbus:data:H
eizungsanlage:HeizkreisWerte:cHeizkreisWandVorlaufSollTemperatur:number=46.0}. readValueType=int16, readIndex=Optional[1031], readSubIndex(or 0)=0, extractIndex=1 -> numeric value 92 and bo
olValue=true. Registers RegisterArrayWrappingInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff f
f ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff f
f ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@56dda554[slaveId=1,functionCode=READ_INPUT_REGISTERS
2020-03-09 09:03:36.855 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisWerte:cHeizkreisFussbodenVorlaufIstTemperatur channels updated: {modbus:da
ta:Heizungsanlage:HeizkreisWerte:cHeizkreisFussbodenVorlaufIstTemperatur:number=36.0}. readValueType=int16, readIndex=Optional[1060], readSubIndex(or 0)=0, extractIndex=30 -> numeric value
72 and boolValue=true. Registers RegisterArrayWrappingInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff f
f ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff f
f ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@56dda554[slaveId=1,functionCode=READ_INPUT_
2020-03-09 09:03:36.858 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisWerte:cHeizkreisFussbodenVorlaufSollTemperatur channels updated: {modbus:d
ata:Heizungsanlage:HeizkreisWerte:cHeizkreisFussbodenVorlaufSollTemperatur:number=30.0}. readValueType=int16, readIndex=Optional[1061], readSubIndex(or 0)=0, extractIndex=31 -> numeric valu
e 60 and boolValue=true. Registers RegisterArrayWrappingInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@56dda554[slaveId=1,functionCode=READ_INPU
2020-03-09 09:03:37.922 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:AnlagenWerte received registers RegisterArrayWrappingInputRegister(00 45 00 5c 00
28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff) f
or request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@36359493[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=0,length=88,maxTries=5]
2020-03-09 09:03:37.926 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:AnlagenWerte:cKesselTemperatur channels updated: {modbus:data:Heizungsanlage:Anlage
nWerte:cKesselTemperatur:number=34.5}. readValueType=int16, readIndex=Optional[0], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 69 and boolValue=true. Registers RegisterArrayWrappi
ngInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00
00 00 00 00 00 ff ff ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@36359493[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=0,length=88,maxTries=5]
2020-03-09 09:03:37.927 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:AnlagenWerte:cAbgasTemperatur channels updated: {modbus:data:Heizungsanlage:Anlagen
Werte:cAbgasTemperatur:number=92}. readValueType=int16, readIndex=Optional[1], readSubIndex(or 0)=0, extractIndex=1 -> numeric value 92 and boolValue=true. Registers RegisterArrayWrappingIn
putRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00
2020-03-09 09:03:37.933 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:AnlagenWerte:cRestsauerstoffgehalt channels updated: {modbus:data:Heizungsanlage:An
lagenWerte:cRestsauerstoffgehalt:number=-0.1}. readValueType=int16, readIndex=Optional[3], readSubIndex(or 0)=0, extractIndex=3 -> numeric value -1 and boolValue=true. Registers RegisterArr
ayWrappingInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ff ff 00 00 00 00 00 00 ff ff ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@36359493[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=0,length=88,maxTries=5]
2020-03-09 09:03:37.933 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:AnlagenWerte:cBetriebsstunden channels updated: {}. readValueType=int16, readIndex=
Optional[20], readSubIndex(or 0)=0, extractIndex=20 -> numeric value -1 and boolValue=true. Registers RegisterArrayWrappingInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff f
f ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff f
f ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff) for request ModbusPollerThingHandlerImp
2020-03-09 09:03:37.938 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:AnlagenWerte:cFuellstandPelletbehaelter channels updated: {modbus:data:Heizungsanla
ge:AnlagenWerte:cFuellstandPelletbehaelter:number=-0.004830917874396135}. readValueType=int16, readIndex=Optional[21], readSubIndex(or 0)=0, extractIndex=21 -> numeric value -1 and boolValu
e=true. Registers RegisterArrayWrappingInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff f
f ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff f
f ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@36359493[slaveId=1,functionCode=READ_INPUT_REGISTERS,start
2020-03-09 09:03:37.939 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:AnlagenWerte:cStundenSeitLetzterWartung channels updated: {}. readValueType=int16,
readIndex=Optional[55], readSubIndex(or 0)=0, extractIndex=55 -> numeric value -1 and boolValue=true. Registers RegisterArrayWrappingInputRegister(00 45 00 5c 00 28 ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 48 00 3c 00 28 ff ff ff ff ff ff ff ff ff ff ff
ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 00 ff ff ff ff) for request ModbusPollerThing
2020-03-09 09:03:37.944 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Index=81 with type=int16 is out-of-bounds given registers of size 65
at org.openhab.io.transport.modbus.ModbusBitUtilities.extractStateFromRegisters(ModbusBitUtilities.java:108) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.onRegisters(ModbusDataThingHandler.java:686) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator.lambda$0(ModbusPollerThingHandlerImpl.java:95) ~[?:?]
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:891) ~[?:1.8.0_163]
at org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator.onRegisters(ModbusPollerThingHandlerImpl.java:95) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusLibraryWrapper.invokeCallbackWithResponse(ModbusLibraryWrapper.java:286) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.lambda$1(ModbusManagerImpl.java:167) ~[?:?]
at org.openhab.io.transport.modbus.internal.SimpleStopWatch.timeRunnable(SimpleStopWatch.java:152) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:166) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:1) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl.executeOperation(ModbusManagerImpl.java:575) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl.lambda$15(ModbusManagerImpl.java:723) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_163]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) ~[?:1.8.0_163]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_163]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) ~[?:1.8.0_163]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_163]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_163]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_163]
2020-03-09 09:03:38.150 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:BoilerWerte received registers RegisterArrayWrappingInputRegister(00 59 00 28 00
37 00 00 00 62 00 5f 00 00 00 5c ff 9e 00 00 01 c6 00 00 00 00 00 00 00 62 00 32 00 3f 00 39 ff 9e 01 fe 09 ea 3a 83 05 15 05 15 00 00 00 00 00 00 00 8c 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 04 46 00 00 00 00 00 00 1b 27 00 0b 00 34 01 08 0a 14 00 08 00 00 00 00 00 00 00 00 00 00 15 54 09 ea 00 00 00 00 00 00 00 00 00 00 15 54 07 5e 07 5e 00 00 00
00 00 00 00 00 00 00 00 00 09 c1 ff fb 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 65 00 00 00 3e 00 00 00 00 02 7d ff ff) for request ModbusPollerThingHandlerImpl.ModbusPoller
ReadRequest@60b75489[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=1630,length=4,maxTries=5]
2020-03-09 09:03:38.154 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:BoilerWerte:cBoilerTemperatur channels updated: {modbus:data:Heizungsanlage:BoilerW
erte:cBoilerTemperatur:number=44.5}. readValueType=int16, readIndex=Optional[1630], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 89 and boolValue=true. Registers RegisterArrayWrapp
ingInputRegister(00 59 00 28 00 37 00 00 00 62 00 5f 00 00 00 5c ff 9e 00 00 01 c6 00 00 00 00 00 00 00 62 00 32 00 3f 00 39 ff 9e 01 fe 09 ea 3a 83 05 15 05 15 00 00 00 00 00 00 00 8c 00 0
0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 46 00 00 00 00 00 00 1b 27 00 0b 00 34 01 08 0a 14 00 08 00 00 00 00 00 00 00 00 00 00 15 54 09 ea 00 00 00 00 00 00 00 00 0
0 00 15 54 07 5e 07 5e 00 00 00 00 00 00 00 00 00 00 00 00 09 c1 ff fb 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 65 00 00 00 3e 00 00 00 00 02 7d ff ff) for request ModbusPol
lerThingHandlerImpl.ModbusPollerReadRequest@60b75489[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=1630,length=4,maxTries=5]
2020-03-09 09:03:38.155 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:BoilerWerte:cBoilerPumpenansteuerung channels updated: {modbus:data:Heizungsanlage:
BoilerWerte:cBoilerPumpenansteuerung:number=55}. readValueType=int16, readIndex=Optional[1632], readSubIndex(or 0)=0, extractIndex=2 -> numeric value 55 and boolValue=true. Registers Regist
erArrayWrappingInputRegister(00 59 00 28 00 37 00 00 00 62 00 5f 00 00 00 5c ff 9e 00 00 01 c6 00 00 00 00 00 00 00 62 00 32 00 3f 00 39 ff 9e 01 fe 09 ea 3a 83 05 15 05 15 00 00 00 00 00 0
0 00 8c 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 46 00 00 00 00 00 00 1b 27 00 0b 00 34 01 08 0a 14 00 08 00 00 00 00 00 00 00 00 00 00 15 54 09 ea 00 00 00 00 0
0 00 00 00 00 00 15 54 07 5e 07 5e 00 00 00 00 00 00 00 00 00 00 00 00 09 c1 ff fb 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 65 00 00 00 3e 00 00 00 00 02 7d ff ff) for reque
st ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@60b75489[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=1630,length=4,maxTries=5]
2020-03-09 09:03:38.377 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:PufferWerte received registers RegisterArrayWrappingInputRegister(00 68 00 fe 00
00 ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@5e656454[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=2000,length=10,maxTries=5]
2020-03-09 09:03:38.380 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:PufferWerte:cPufferTemperaturOben channels updated: {modbus:data:Heizungsanlage:Puf
ferWerte:cPufferTemperaturOben:number=52.0}. readValueType=int16, readIndex=Optional[2000], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 104 and boolValue=true. Registers RegisterA
rrayWrappingInputRegister(00 68 00 fe 00 00 ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@5e656454[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=2000,length=10
,maxTries=5]
2020-03-09 09:03:38.383 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:PufferWerte:cPufferTemperaturMitte channels updated: {modbus:data:Heizungsanlage:Pu
fferWerte:cPufferTemperaturMitte:number=127.0}. readValueType=int16, readIndex=Optional[2001], readSubIndex(or 0)=0, extractIndex=1 -> numeric value 254 and boolValue=true. Registers Regist
erArrayWrappingInputRegister(00 68 00 fe 00 00 ff ff) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@5e656454[slaveId=1,functionCode=READ_INPUT_REGISTERS,start=2000,length
=10,maxTries=5]
2020-03-09 09:03:38.387 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:PufferWerte:cPufferTemperaturUnten channels updated: {modbus:data:Heizungsanlage:Pu
fferWerte:cPufferTemperaturUnten:number=0.0}. readValueType=int16, readIndex=Optional[2002], readSubIndex(or 0)=0, extractIndex=2 -> numeric value 0 and boolValue=false. Registers RegisterA
,maxTries=5]
2020-03-09 09:03:38.388 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:PufferWerte:cPufferPumpenansteuerung channels updated: {modbus:data:Heizungsanlage:
PufferWerte:cPufferPumpenansteuerung:number=-1}. readValueType=int16, readIndex=Optional[2003], readSubIndex(or 0)=0, extractIndex=3 -> numeric value -1 and boolValue=true. Registers Regist
=10,maxTries=5]
2020-03-09 09:03:38.389 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Index=6 with type=int16 is out-of-bounds given registers of size 4
2020-03-09 09:03:38.602 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.ClassCastException: net.wimpi.modbus.msg.ReadInputRegistersResponse cannot be cast to net.wimpi.modbus.msg.ReadMultipleRegistersResponse
at org.openhab.io.transport.modbus.internal.ModbusLibraryWrapper.invokeCallbackWithResponse(ModbusLibraryWrapper.java:284) ~[?:?]
2020-03-09 09:03:38.829 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:AnlagenParameter2 received registers RegisterArrayWrappingInputRegister(00 8c 00
10) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@4ceb15b0[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=319,length=2,maxTries=5]
2020-03-09 09:03:38.832 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:AnlagenParameter2:cPelletRestbestand channels updated: {modbus:data:Heizungsanlage:
AnlagenParameter2:cPelletRestbestand:number=14.0}. readValueType=int16, readIndex=Optional[319], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 140 and boolValue=true. Registers Regi
sterArrayWrappingInputRegister(00 8c 00 10) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@4ceb15b0[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=319,length=2,maxTr
ies=5]
2020-03-09 09:03:39.074 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:KesselFernsteuerungParameter received registers RegisterArrayWrappingInputRegiste
r(00 1e 00 00) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@5c25ce24[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=8000,length=50,maxTries=5]
2020-03-09 09:03:39.075 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:KesselFernsteuerungParameter:cHeizkreisWandVorlaufSolltemperatur channels updated:
{}. readValueType=int16, readIndex=Optional[8000], readSubIndex(or 0)=0, extractIndex=0 -> numeric value 30 and boolValue=true. Registers RegisterArrayWrappingInputRegister(00 1e 00 00) for
2020-03-09 09:03:39.075 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:KesselFernsteuerungParameter:cHeizkreisFussbodenVorlaufSolltemperatur channels upda
ted: {}. readValueType=int16, readIndex=Optional[8001], readSubIndex(or 0)=0, extractIndex=1 -> numeric value 0 and boolValue=false. Registers RegisterArrayWrappingInputRegister(00 1e 00 00
2020-03-09 09:03:39.082 [INFO ] [e.smarthome.model.script.Beleuchtung] - Wohnzimmer Trigger ausgel▒st: 211.0333948429994
2020-03-09 09:03:39.076 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.IllegalArgumentException: Index=18 with type=int16 is out-of-bounds given registers of size 2
at org.openhab.io.transport.modbus.internal.ModbusLibraryWrapper.invokeCallbackWithResponse(ModbusLibraryWrapper.java:283) ~[?:?]
2020-03-09 09:03:39.091 [INFO ] [e.smarthome.model.script.Beleuchtung] - Wohnzimmer Status Lampen: OFF
2020-03-09 09:03:39.734 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:HeizkreisParameter received registers RegisterArrayWrappingInputRegister(00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@6e70b6ef[slaveId=1,f
unctionCode=READ_MULTIPLE_REGISTERS,start=1030,length=64,maxTries=5]
2020-03-09 09:03:39.736 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisParameter:cWandVorlaufWunschPlus10GRad channels updated: {}. readValueType
=int16, readIndex=Optional[1031], readSubIndex(or 0)=0, extractIndex=1 -> numeric value 0 and boolValue=false. Registers RegisterArrayWrappingInputRegister(00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@6e70b6ef[slaveId=1,functionCode=READ_MULTIPLE
2020-03-09 09:03:39.737 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisParameter:cWandVorlaufWunschMinus10GRad channels updated: {}. readValueTyp
e=int16, readIndex=Optional[1032], readSubIndex(or 0)=0, extractIndex=2 -> numeric value 0 and boolValue=false. Registers RegisterArrayWrappingInputRegister(00 00 00 00 00 00 00 00 00 00 00
2020-03-09 09:03:39.738 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisParameter:cWandVorlaufTemperaturAbsenkung channels updated: {}. readValueT
ype=int16, readIndex=Optional[1033], readSubIndex(or 0)=0, extractIndex=3 -> numeric value 0 and boolValue=false. Registers RegisterArrayWrappingInputRegister(00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@6e70b6ef[slaveId=1,functionCode=READ_MULTI
2020-03-09 09:03:39.738 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisParameter:cFussbodenVorlaufWunschMinus10GRad channels updated: {}. readVal
ueType=int16, readIndex=Optional[1062], readSubIndex(or 0)=0, extractIndex=32 -> numeric value 0 and boolValue=false. Registers RegisterArrayWrappingInputRegister(00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@6e70b6ef[slaveId=1,functionCode=READ_M
2020-03-09 09:03:39.739 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:HeizkreisParameter:cFussbodenVorlaufTemperaturAbsenkung channels updated: {}. readV
alueType=int16, readIndex=Optional[1063], readSubIndex(or 0)=0, extractIndex=33 -> numeric value 0 and boolValue=false. Registers RegisterArrayWrappingInputRegister(00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00) for request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@6e70b6ef[slaveId=1,functionCode=READ
2020-03-09 09:03:39.958 [DEBUG] [handler.ModbusPollerThingHandlerImpl] - Thing modbus:poller:Heizungsanlage:BoilerParameter received registers RegisterArrayWrappingInputRegister(ff ff 00 5a
00 78 00 14 00 96 00 28 00 24 00 1a 00 14 00 28 00 24 00 3c 00 8c 00 00 00 01 00 00 00 96 00 78 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 3c 00 46 00
10 00 5a 00 28 00 24 00 1a 00 14 00 28 00 20 00 14 00 8c 00 00 00 01 00 00 ff ff 00 96 00 78 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 50 00 78 00 1e) for
request ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@49939ce8[slaveId=1,functionCode=READ_MULTIPLE_REGISTERS,start=1631,length=4,maxTries=5]
2020-03-09 09:03:39.959 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:BoilerParameter:cBoilerSollTemperatur channels updated: {}. readValueType=int16, re
adIndex=Optional[1631], readSubIndex(or 0)=0, extractIndex=0 -> numeric value -1 and boolValue=true. Registers RegisterArrayWrappingInputRegister(ff ff 00 5a 00 78 00 14 00 96 00 28 00 24 0
0 1a 00 14 00 28 00 24 00 3c 00 8c 00 00 00 01 00 00 00 96 00 78 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 3c 00 46 00 10 00 5a 00 28 00 24 00 1a 00 1
4 00 28 00 20 00 14 00 8c 00 00 00 01 00 00 ff ff 00 96 00 78 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 50 00 78 00 1e) for request ModbusPollerThingHandler
2020-03-09 09:03:39.960 [DEBUG] [ernal.handler.ModbusDataThingHandler] - Thing modbus:data:Heizungsanlage:BoilerParameter:cBoilerNachladenStartTemperatur channels updated: {}. readValueType
=int16, readIndex=Optional[1632], readSubIndex(or 0)=0, extractIndex=1 -> numeric value 90 and boolValue=true. Registers RegisterArrayWrappingInputRegister(ff ff 00 5a 00 78 00 14 00 96 00
28 00 24 00 1a 00 14 00 28 00 24 00 3c 00 8c 00 00 00 01 00 00 00 96 00 78 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 3c 00 46 00 10 00 5a 00 28 00 24
00 1a 00 14 00 28 00 20 00 14 00 8c 00 00 00 01 00 00 ff ff 00 96 00 78 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff 00 50 00 78 00 1e) for request ModbusPollerTh
