i just bought a Moes HY368 TRV with Zigbee and connected it via the CC2531EMK stick to OH3. It also has detected 20 channels automatically. However, the created thing returns:
HANDLER_INITIALIZING_ERROR
No supported clusters found
I was browsing a little bit through the forum and might need your input to the following questions:
could this be problem with the CC2531EMK and its firmware?
can i run zigbee2mqtt on the same device(Rpi 3+) where OH3 is installed?
would you rather flash the HY368 with an alternative firmware?
If option 2 ist posssible, i guess this would be the easiest solution, correcct?
thank you for your reply. I dint want to start a bigger discussion, rather having some learnings shared from other and how they approached it.
i have attached a log based on the documentation to this post. Maybe @chris
can have a look at it.
