Hi
I am new to OH, I just have finished the setup of the system and I have an android app with 1 connected dimmer. The system is working fine and I have a basic understanding how this thing works.
I am located in US and I used a deal at slickdeals and purchased 3 monoprice socket wall sockets. The price was good, z-wave network so it should work - I thought. My OH2 PaperUI cannot find this device. I am surprised because Z-Wave devices - as I read - are super easy to manage and there are no issues with them.
Does anyone have this monoprice device paired with OH2?
Please advise.
Well I checked and it is not on the list. If it was on the list I assume it would be plug and play device. That’s why I am asking if anyone has it connected.
It is not paired and I don’t know how to pair this particular device. When I click scan available items or whatever button it is (I don’t have access to my OH2 now) it says nothing to add and I can add it manually but I don’t know how to add it
I think the answer is within your earlier statement about
You absolutely won’t see it in OH until it is paired with the controller. From what it looks like online at the monoprice documentation (https://downloads.monoprice.com/files/manuals/15654_Manual_161024.pdf) The button to pair it to the controller is on the bottom of the device. The instructions for inclusion into your z-wave network (pairing) is on page 5 of that URL/PDF. After you pair/include it with your controller, OH will be able to see it.
Just because the name/brand doesn’t show as listed doesn’t mean the actual manufacturer device ID of the unit isn’t already compatible… but you will never know until the device is included/paired to the controller.
Where on earth did you see this? Super Easy is not something I’d normally associate zWave with… Maybe if you stick to one vendors device/controller/software, but there’s no way I’d use words like easy to use or reliable in conjunction with zWave.
I have this same device (5 actually) and I had to pair it directly with my usb z-wave stick. Then it showed up for me in HABmin. What Z-wave gateway do you have? I use the Aeotec Z-Stick Gen5 and need to hold down a button close to the device, then hold down the button on the device itself to pair.
