I have 2 Pi’s one running a temperature/humidity sensor that controls a dehumidifier using a python script, and the second running OpenHab. Using Mosequitto I am passing the temperature and humidity data to the second pi running my OpenHab environment.
The result I am after is to try and turn on/off a dummy switch if the humidity rises above or drops below a certain level.
In my items I have
Number LivingroomHumidity "Humidity [%.1f %%]" (GF_Living) {mqtt="<[mymosquitto:home/bedroom/humidity:state:default]"}
Switch Dehymidifier_GF_Living "Dehumidifier" (GF_Living)
The data is real but the switch is a dummy so wont actually activate anything.
in my rules I have
import org.openhab.core.library.types.*
import org.openhab.core.library.items.SwitchItem
rule "LivingRoomDehumidifierOn"
Item LivingroomHumidity received update
val temp = LivingroomHumidity.state
val oldstate = Dehymidifier_GF_Living.last.state as OnOffType
if(temp > 52.0 && oldstate=OFF){
sendCommand(Dehymidifier_GF_Living,ON)
if(temp < 48.0 && oldstate=ON){
sendCommand(Dehymidifier_GF_Living,OFF)
As the switch is not being activated I am doing something wrong.
Any tips welcome.
1st: val temp = LivingroomHumidity.state as DecimalType
2nd: val oldstate = Dehymidifier_GF_Living.historicState(now.minusSeconds(2)).state as OnOffType
I’m not sure, if this is the correct way
You could use logInfo("myrule","value of temp is {} and value of oldstate is {}",temp,oldstate.toString)
to see if you are getting the correct states.
Ah. You don’t need historicState for Dehymidifier… you can use just Dehymidifier_GF_Living.state as OnOffType
Thanks that helped a lot.
It told me that the dummy switch was in a state of ’ Uninitialized’ so adding a rule that took care of that scenario got the switch to turn on.
With the debug information I also noticed that once turned off the switch would not turn on again which was due to me using a single = rather than a double.
So having changed my rules every thing is now working
val oldstate = Dehymidifier_GF_Living.state
if(temp > 52.0 && oldstate==Uninitialized){
if(temp > 52.0 && oldstate==OFF ){
if(temp < 48.0 && oldstate==ON){
