Hi
I’m trying to add a second Anel-Device to my openHAB 1.8.1.
With one device it’s working…with the second I get this error:
2016-04-23 16:47:00.614 [ERROR] [a.internal.AnelConnectorThread] - Error occured when connecting to NET-PwrCtrl device
java.net.BindException: Address already in use
_ at java.net.PlainDatagramSocketImpl.bind0(Native Method) ~[na:1.8.0_65]_
_ at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:94) ~[na:1.8.0_65]_
_ at java.net.DatagramSocket.bind(DatagramSocket.java:392) ~[na:1.8.0_65]_
_ at java.net.DatagramSocket.(DatagramSocket.java:242) ~[na:1.8.0_65]_
_ at java.net.DatagramSocket.(DatagramSocket.java:299) ~[na:1.8.0_65]_
_ at java.net.DatagramSocket.(DatagramSocket.java:271) ~[na:1.8.0_65]_
_ at org.openhab.binding.anel.internal.AnelUDPConnector.connect(AnelUDPConnector.java:72) ~[na:na]_
_ at org.openhab.binding.anel.internal.AnelConnectorThread.run(AnelConnectorThread.java:220) ~[na:na]_
2016-04-23 16:47:00.781 [WARN ] [a.internal.AnelConnectorThread] - Closing NET-PwrCtrl message listener
I didn’t find in Binding-Description that this should not work:
IP or network address (optional but recommended, defaults to ‘net-control’)
anel:anel1.host=192.168.1.57
anel:anel2.host=192.168.1.65
Any help?
Michael
