I installed 2.5M1 as was recommended here to solve ZWave issues that I found out were part of the latest snapshot. I am still having quite a bit of difficulty.
I do have alot of devices. About 50. Currently, nothing works. Whats funny is that if you look at the log, everything appears alright. I do still also get alot of the following error:
Request node info not placed on stack due to error.
Sometimes I get some things to work some of the time. This stuff just doesn’t seem to just work. All the rest of my bindings seem fine. This one has been virtually constant trouble.
16:01:05.000 [nt.ItemStatePredictedEvent] - ML_WindowWall_Lights3 predicted to become ON
2019-07-12 16:01:05.004 [nt.ItemStatePredictedEvent] - ML_PowderRoom_Switch1 predicted to become ON
2019-07-12 16:01:05.009 [nt.ItemStatePredictedEvent] - ML_Garage_Switch1 predicted to become ON
2019-07-12 16:01:05.013 [vent.ItemStateChangedEvent] - ML_Staircase_Chandelier changed from 0 to 100
2019-07-12 16:01:05.016 [vent.ItemStateChangedEvent] - ML_WindowWall_Lights1 changed from 0 to 100
2019-07-12 16:01:05.020 [vent.ItemStateChangedEvent] - ML_WindowWall_Lights2 changed from 0 to 100
2019-07-12 16:01:05.024 [nt.ItemStatePredictedEvent] - BS_Hallway_Dimmer1 predicted to become 100
2019-07-12 16:01:05.028 [vent.ItemStateChangedEvent] - ML_WindowWall_Lights3 changed from OFF to ON
2019-07-12 16:01:05.036 [vent.ItemStateChangedEvent] - ML_PowderRoom_Switch1 changed from OFF to ON
2019-07-12 16:01:05.038 [vent.ItemStateChangedEvent] - ML_Garage_Switch1 changed from OFF to ON
2019-07-12 16:01:05.044 [nt.ItemStatePredictedEvent] - BS_MainRoom_Switch1 predicted to become ON
2019-07-12 16:01:05.049 [vent.ItemStateChangedEvent] - BS_Hallway_Dimmer1 changed from 0 to 100
2019-07-12 16:01:05.054 [nt.ItemStatePredictedEvent] - BS_Shop_Switch1 predicted to become ON
2019-07-12 16:01:05.057 [nt.ItemStatePredictedEvent] - BS_WineCellar_Switch1 predicted to become ON
2019-07-12 16:01:05.066 [vent.ItemStateChangedEvent] - BS_MainRoom_Switch1 changed from OFF to ON
2019-07-12 16:01:05.071 [vent.ItemStateChangedEvent] - BS_Shop_Switch1 changed from OFF to ON
2019-07-12 16:01:05.073 [vent.ItemStateChangedEvent] - BS_WineCellar_Switch1 changed from OFF to ON
2019-07-12 16:01:05.076 [nt.ItemStatePredictedEvent] - BS_Hallway_Trains_Dimmer1 predicted to become 100
2019-07-12 16:01:05.080 [vent.ItemStateChangedEvent] - BS_Hallway_Trains_Dimmer1 changed from 0 to 100
2019-07-12 16:01:05.090 [nt.ItemStatePredictedEvent] - BS_MainRoom_Pendants_Dimmer1 predicted to become 100
2019-07-12 16:01:05.093 [vent.ItemStateChangedEvent] - BS_MainRoom_Pendants_Dimmer1 changed from 0 to 100
2019-07-12 16:01:05.096 [nt.ItemStatePredictedEvent] - CL_LaundryRoom_Lights1 predicted to become NULL
2019-07-12 16:01:05.100 [nt.ItemStatePredictedEvent] - CL_CedarCloset_Switch1 predicted to become ON
2019-07-12 16:01:05.104 [vent.ItemStateChangedEvent] - CL_CedarCloset_Switch1 changed from OFF to ON
2019-07-12 16:01:05.106 [nt.ItemStatePredictedEvent] - CL_GuestSuiteLounge_Dimmer1 predicted to become 100
2019-07-12 16:01:05.112 [vent.ItemStateChangedEvent] - CL_GuestSuiteLounge_Dimmer1 changed from 0 to 100
2019-07-12 16:01:05.115 [nt.ItemStatePredictedEvent] - MS_Bedroom_Outlets predicted to become ON
2019-07-12 16:01:05.119 [vent.ItemStateChangedEvent] - MS_Bedroom_Outlets changed from OFF to ON
2019-07-12 16:01:05.122 [nt.ItemStatePredictedEvent] - MS_Bathroom_Switch1 predicted to become ON
2019-07-12 16:01:05.129 [vent.ItemStateChangedEvent] - MS_Bathroom_Switch1 changed from OFF to ON
2019-07-12 16:01:05.132 [nt.ItemStatePredictedEvent] - MS_Deck_Dimmer predicted to become 100
2019-07-12 16:01:05.136 [vent.ItemStateChangedEvent] - MS_Deck_Dimmer changed from 0 to 100
2019-07-12 16:01:05.140 [nt.ItemStatePredictedEvent] - MS_Lounge_Dimmer1 predicted to become 100
2019-07-12 16:01:05.144 [vent.ItemStateChangedEvent] - MS_Lounge_Dimmer1 changed from 0 to 100
2019-07-12 16:01:05.147 [nt.ItemStatePredictedEvent] - MS_Bathroom_Switch1 predicted to become ON
2019-07-12 16:01:05.149 [nt.ItemStatePredictedEvent] - MS_Bedroom_Hall_Switch predicted to become ON
2019-07-12 16:01:05.152 [vent.ItemStateChangedEvent] - MS_Bedroom_Hall_Switch changed from OFF to ON
2019-07-12 16:01:05.159 [nt.ItemStatePredictedEvent] - DF_Outdoor_Front_Lights1 predicted to become ON
2019-07-12 16:01:05.165 [vent.ItemStateChangedEvent] - DF_Outdoor_Front_Lights1 changed from OFF to ON
