i updated OH from 3.0 to 3.1 on my Rasp. 3 and had some troubles getting OH to start again:
Warning: The unit file, source configuration file or drop-ins of openhab.service changed on disk. Run 'systemctl daemon-reload' to reload units.
After the deamon-reload, OH starts but now my mosquitto does not start on boot.
[19:42:18] openhabian@openHABianDevice:~$ sudo systemctl status mosquitto.service -l
● mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/mosquitto.service.d
└─override.conf
Active: failed (Result: exit-code) since Sat 2021-08-21 19:36:38 CEST; 6min ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Main PID: 667 (code=exited, status=1/FAILURE)
Aug 21 19:36:38 openHABianDevice systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
Aug 21 19:36:38 openHABianDevice systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
Aug 21 19:36:38 openHABianDevice systemd[1]: Stopped Mosquitto MQTT v3.1/v3.1.1 Broker.
Aug 21 19:36:38 openHABianDevice systemd[1]: mosquitto.service: Start request repeated too quickly.
Aug 21 19:36:38 openHABianDevice systemd[1]: mosquitto.service: Failed with result 'exit-code'.
Aug 21 19:36:38 openHABianDevice systemd[1]: Failed to start Mosquitto MQTT v3.1/v3.1.1 Broker.
with “mosquitto” the broker works
[19:44:56] openhabian@openHABianDevice:~$ mosquitto
1629567946: mosquitto version 1.5.7 starting
1629567946: Using default config.
1629567946: Opening ipv4 listen socket on port 1883.
1629567946: Opening ipv6 listen socket on port 1883.
1629567946: New connection from 192.168.1.122 on port 1883.
1629567946: New client connected from 192.168.1.122 as DVES_8B2C06 (c1, k30, u'openhabian').
1629567946: New connection from 192.168.1.121 on port 1883.
1629567946: New client connected from 192.168.1.121 as DVES_187459 (c1, k30, u'openhabian').
1629567957: New connection from 192.168.1.123 on port 1883.
1629567957: New client connected from 192.168.1.123 as DVES_8ACC52 (c1, k30, u'openhabian').
1629567976: New connection from 192.168.1.100 on port 1883.
1629567976: New client connected from 192.168.1.100 as openHAB (c1, k60, u'openhabian').
PS: Also Grafana does not start and i think InfluxDB too.
[20:12:35] openhabian@openHABianDevice:~$ sudo systemctl status influxdb.service -l
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: activating (start) since Sat 2021-08-21 20:12:33 CEST; 7s ago
Docs: https://docs.influxdata.com/influxdb/
Cntrl PID: 16018 (influxd-systemd)
Tasks: 11 (limit: 2178)
CGroup: /system.slice/influxdb.service
├─16018 /bin/bash -e /usr/lib/influxdb/scripts/influxd-systemd-start.sh
├─16019 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
└─16079 sleep 1
[20:14:24] openhabian@openHABianDevice:~$ sudo systemctl start influxdb
Job for influxdb.service failed because the control process exited with error code.
See "systemctl status influxdb.service" and "journalctl -xe" for details.
[20:14:34] openhabian@openHABianDevice:~$ journalctl -xe
Aug 21 20:14:51 openHABianDevice comitup[16953]: conf.ap_password
Aug 21 20:14:51 openHABianDevice comitup[16953]: File "/usr/share/comitup/comitup/states.py", line 322, in init_states
Aug 21 20:14:51 openHABianDevice comitup[16953]: nmmon.init_nmmon()
Aug 21 20:14:51 openHABianDevice comitup[16953]: File "/usr/share/comitup/comitup/nmmon.py", line 146, in init_nmmon
Aug 21 20:14:51 openHABianDevice comitup[16953]: modemgr.get_ap_device(),
Aug 21 20:14:51 openHABianDevice comitup[16953]: File "/usr/share/comitup/comitup/modemgr.py", line 68, in get_ap_device
Aug 21 20:14:51 openHABianDevice comitup[16953]: ap_device = devs[0]
Aug 21 20:14:51 openHABianDevice comitup[16953]: IndexError: list index out of range
Aug 21 20:14:51 openHABianDevice systemd[1]: comitup.service: Main process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- An ExecStart= process belonging to unit comitup.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Aug 21 20:14:51 openHABianDevice systemd[1]: comitup.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit comitup.service has entered the 'failed' state with result 'exit-code'.
Aug 21 20:14:51 openHABianDevice systemd[1]: Failed to start Comitup Wifi Management.
-- Subject: A start job for unit comitup.service has failed
-- A start job for unit comitup.service has finished with a failure.
-- The job identifier is 34131 and the job result is failed.
Aug 21 20:14:53 openHABianDevice influxd-systemd-start.sh[16904]: ts=2021-08-21T18:14:53.766998Z lvl=info msg="Reading file" log_id=0W6UaypG000 engine=tsm1 service
Any Ideas ?
Thanks!
