Not sure if someone can help me with this.
I installed mosquitto in a docker and everything looks file
This is what I read in the logfile
1671825240: mosquitto version 2.0.15 starting
1671825240: Config loaded from /mosquitto/config/mosquitto.conf.
1671825240: Opening ipv4 listen socket on port 1883.
1671825240: Opening ipv6 listen socket on port 1883.
1671825240: Opening ipv4 listen socket on port 9001.
1671825240: Opening ipv6 listen socket on port 9001.
1671825240: mosquitto version 2.0.15 running
this is the compose file
docker run \
--name mosquitto \
--net=bridge \
-d \
-p 1883:1883 \
-p 9001:9001 \
-v /volume1/docker/mosquitto/config:/mosquitto/config \
-v /volume1/docker/mosquitto/data:/mosquitto/data \
-v /volume1/docker/mosquitto/log:/mosquitto/log \
--restart=always \
eclipse-mosquitto:latest
when I want to connect with Openhab I get the following error
io.netty.channel.ConnectTimeoutException: connection timed out: /192.168.100.51:1883
Openhab 3.4.0.RC1 is running in a docker with IP address 192.168.100.90
