No, that’s OK. Because the motion driven dim is always 30, if its less than 31 im happy for it to go off.
I only want it to stay ON if its above that.
Note that the last version of the rule posted does this regardless of the current state of it.
If you manually set “60”, the next motion will set it to “30”.
Im not following. Feel free to suggest a rule rossko that fixes the issue, I’m no expert.
The original rule worked perfectly for motion driven lights but would switch off, even if the dim was above 30
