rule “Bewegungen zählen (inklusive ausser Haus)“
Item eyemove changed from 0 to 1
if (nog_tag.state == ON && eyemove.state == 1) {
sum = sum + 1;
eyemovegesamt.postUpdate(sum)
else
if (nog_tag.state == OFF && eyemove.state == 1) {
suma = suma + 1;
eyemovegesamta.postUpdate(suma)
pushover(”[openHAB - ALARM!] Bewegung ohne Präsenz registiert!”)
Where did you define sum and suma? Is eyemove of type number? Why do you double check state of eyemove? (rule trigger is only to trigger if changed from 0 to 1, so eyemove.state is 1)
I would suggest to simplify the rule:
rule "Bewegungen zählen (inklusive ausser Haus)"
Item eyemove changed to 1 // could could be NULL to 1 either
if (!(eyemovegesamt.state instanceof Number))
eyemovegesamt.postUpdate(0) // ensure the item is initialized
if (!(eyemovegesamta.state instanceof Number))
eyemovegesamta.postUpdate(0) // ensure the item is initialized
if (nog_tag.state == ON)
eyemovegesamt.postUpdate((eyemovegesamt.state as Number) + 1) // add 1 to actual state
else {
eyemovegesamta.postUpdate((eyemovegesamta.state as Number) + 1) // add 1 to actual state
pushover("[openHAB - ALARM!] Bewegung ohne Präsenz registiert!")
You won’t need the first two if clauses if you do a persistence with restoreOnStartup strategy (of course after a initial initializing)
//_________________________________________________________________________________________
if (nog_tag.state == "ON")
else {
eyemovegesamt/a is define as Number Item and set to 0 on startup
