On both my sensors i get motion detected and values for lumi and temp.
I think its safe to say that everything is working as it should, what do you guys think @chris, @Avner?
As a note: i just updated the device parameter descriptions so they show up nicely and do not trow a error on the database site
I think so. I still have this problem, where after a while zwave events stop coming up, and then I get a Queue Full exception error.
I connected another device and when this happened, I stopped seeing events from the other device as well, so I think this is a more general problem that is related to the zwave thread and not specifically to the HSM100.
I opened another thread for this issue here. @chris do you know what could cause the exception?
Just to be sure, I restarted openhab with the other device only (took the batteries from the HSM100), to see if the Queue Full assertion error still happens, when the HSM100 is not active. So far openhab runs without problem. I’ll keep monitoring… @chris I read that if other dead nodes (of devices that no longer exist) on the zwave stick can create side effects. Is there a way to remove them without resetting the stick?
I doubt that this is related to the HSM100, but if it is, then you’d be better to put the batteries back in and get a log showing the problem. Getting a log that doesn’t show the problem isn’t going to be useful.
This time, there is no Queue Full exception error, but the events still stop after some time.
The flow of events is in note1.
I’m working with a stable build, and the development zwave binding on top. I added the development binding using the steps in note2 (Should I do it differently?)
note1 - flow of events
Started openhab at around 2017-05-06 08:54
OFF/ON events coming from the HASM100 and Fibaro devices at e.g.
– node6 (Fibaro): 2017-05-06 09:01:06.496, 2017-05-06 09:12:10.579
– node3 (HSM100): 2017-05-06 09:01:46.219, 2017-05-06 09:12:10.270
Sorry - but unless it’s a debug log, it’s really of no use.
Also, there are other errors in your file - you are trying to load two zwave bundles so you should also resolve this so you know what version is actually running.
I described in here how the development binding was loaded on top of the stable version. Doesn’t status Active for the development binding (2.1.0.201704162057) indicate that this is the version that is running. please let me know how to install the development version on top of a stable OpenHab2, if my development installation steps are not correct.
There is information on installing the binding in the other thread. I’m not sure what is up, but I don’t think you should normally end up with these exceptions in the log. Anyway, that’s not the issue you want to look at.
This log has limited information and is unfortunately unusable. There is no logging of any zwave messages for example and without this it’s impossible to say what is happening.
@chris, in what way the information is limited in the log?
I configured it to DEBUG and captured the entire time from restarting oh2 until zwave events stopped coming in.
Also, the snapshots note1, and note2 line up with this.
If needed, I’ll capture more log information. Let me know.
note2 OFF/ON events coming from the HASM100 and Fibaro devices
09:00:15.563 6 STATE UPDATE zwave:device:baa75210:node6:alarm_motion ON [OnOffType]
09:01:06.495 6 STATE UPDATE zwave:device:baa75210:node6:alarm_motion OFF [OnOffType]
09:01:46.216 3 RX REQ ApplicationCommandHandler BASIC_SET
As said earlier, the log you posted has no logging of ZWave messages. There are only logs from a couple of classes (no command classes, no ZWave messages).
Maybe there’s another exception somewhere that is bumping out the receive thread. This could then cause the receive buffer overflow and also the lack of logging. It would be well before the log full exception though.
Ok, so maybe the lack of messages is something else. As I suggested, I wonder if there’s another exception somewhere that is causing the receive thread to exit. Another suggestion is that something bad is happening earlier so that the binding stops processing received data, and then at some point later, you get the queue full.
I can’t tie up the exceptions with errors in the logs as the different logs don’t tie up for me.
The error you show above at 09:00:15 is this one -:
This is on the 6 May. If I look in the OH2 log, there is no error at this time on the 6th May. There are 3 exceptions in the OH2 log -:
2017-04-17 05:43:28.805 [ERROR] [WaveSerialHandler$ZWaveReceiveThread] - Exception during ZWave thread.
2017-04-29 02:02:28.219 [ERROR] [WaveSerialHandler$ZWaveReceiveThread] - Exception during ZWave thread.
2017-05-04 06:36:31.001 [ERROR] [WaveSerialHandler$ZWaveReceiveThread] - Exception during ZWave thread.
None of these tie up with either of the logs that you show in note1 or note2 (I’m assuming that’s what you are trying to say when you said it ties up with “this” - “this” being the exceptions?).
Is that what you are trying to show with the log images above?
