I would really try and reset the device, or something so that it doesn’t report the listening flag since I think this is likely to cause problems no matter what is done in the binding. As I’ve said, the listening flag tells the controller that the device is always awake, and quite clearly this device isn’t.
You can certainly try and debug to see if it can be resolved - it might be possible (probably) to resolve the initialisation issue, but I would expect there to be continuing problems with its use.
I think it is a good idea, to indicate to openhab that the device is not listening (instead of working around timeouts). Since I have done everything I could, (from user operation perspective), I’ll try and intercept via the debugger, the point where the device reports as listening and override it with not-listening.
It will not solve the not-listening for the long term (beyond the debug session) but at least I’m hoping to see a “green dot” in habmin, indicating an initialisation complete.
(by the way, I ordered a new zwave controller Aeonlab zstick gen5 - maybe that will help, as well)
The listening flag indicates that the device is running on mains power, so possibly resetting it with power, and without power might fix the problem… maybe
Apparently, connecting to main power does not change the state of the device. The state of device is only set via programming, by setting the “stay awake” parameter to 0, but since it already shows 0 in the configuration parameters (although openhab is reported it as listening), I have to step in with the debugger and check what is going on.
I imported org.openhab.ui.habmin_0.1.6.jar as follows:
clicked right-clicked on launch [openhab-distro master] and chose Import, then selected wizard “General -> Archive File” -> /home/avner/Downloads/org.openhab.ui.habmin_0.1.6.jar -> Finish
After that I executed openhab-distro master -> Debug.
I see messages in the Console pane, and http://localhost:8080 responds, but http://localhost:8080/habmin doesn’t come up.
I am probably not importing habmin properly. Can anyone help me on how to import jar file into the eclipse, so that it’s taking effect in the project?
Did you exclude and include the device again. Normally a device can NOT change its listening flag state without exclusion and re-inclusion as this is (as far as I know) against the Z-Wave protocol.
I meant that there are no physical jumpers on the device that will let you change the listening mode. Connecting to main power will simply avoid draining the power source. The only way to set the listening mode is programatically through the “Stay awake” parameter.
I did program the “stay awake” parameter and exclude/include (while the device was battery operated) in several places like here and here
I still cannot import the imported org.openhab.ui.habmin_0.1.6.jar in a way that when I execute openhab via eclipse, http://localhost:8080/habmin responds (I also commented in here). Can someone guide on how to import habmin jar file into the eclipse, so that it’s taking effect in the project?
Are you sure - this is definately not the case for other devices that have this function, and as I stated earlier, my understanding of the the zwave protocol doesn’t allow devices to change this flag without being excluded and included into the network.
This is a very strange device then. How do you actually know this - is it documented somewhere or is this just your assumption? As above, I would expect the device to need to be excluded and re-included to change the status of the listening flag. I might be wrong, but this is the case for other devices I know of, and consistent with my understanding of the protocol. I’m happy to be corrected though if you have a document that states otherwise.
This is my understanding. How will the device magically differentiate from being connect to battery or main power? In this link the battery connection is simply rewired to main power, just to avoid power drainage. No other magic (such as device mode suddenly changes to “listening”) is mentioned there
The manual states, the way to control the listening / not- listening mode (by setting the flag, and not e.g. by magically recognising that the battery connection is now rewired to a main source):
Setting Stay Awake to a non-zero value will cause EZMotion+ to always be awake.
It also talks about the flag being preserved after exclusion (but as I mentioned before in here, after I excluded and reincluded the device, the value didn’t stick)
Stay Awake is NOT set to the factory default (0) when EZMotion+ is Excluded (reset) from the Z-Wave network.
The only documentation in the manual regarding listening/not-listening mode is the line that I mentioned above.
which is what I did in here, but the value didn’t stick
The magic of electronics I guess. Certainly this is how the Aeon devices work - they detect the power source - it’s not hard to do…
I’m not sure then - to me, this device isn’t working as per my understanding of the ZWave standard if it can change the listening flag without being excluded. I might send an email to my contact in Sigma to check.
I’m not saying that it changes the listening flag without being excluded. All I know is that I’m not sure what is going on, and so I’d like to hook habmin into a openhab within eclipse, find and set a breakpoint in the place where it is being reported “listening” and go from there, but I need help to get there first
I now run zwave binding (2.0.0-SNAPSHOT) (addressed in this discussion thread), together with habmin (org.openhab.ui.habmin_0.1.6.jar) within eclipse.
I added the hsm100 zwave device (Z-Wave Node 34: EZMotion Express Wireless 3-in-1 Sensor).
Paper UI.Configuration.Things and Habmin.Configuration.Things both:
Show the device with icon Online (img1)
Respond immediately to changes in the device. When the battery is taken out from the hsm100, the icon changes to Offline (img2), and when the battery is reinserted the icon changes to back Online (img1).
The log file shows that “init node thread finished” (snippet1)
But there is no xml file for node 34 in userdata/zwave/ (xml files are generated for other zwave devices, e.g light switch - node 19) (snippet2)
Does this indicate that the initialisation of the hasm100 is complete or not?
I thought that an Online icon means that the device finished initialisation (since the hsm100 does not show the specific Unitiialised icon).
Moving on, I forced the zwave binding to recognise the hsm100 to be not-listening by applying a minor code change (see snippet1). After this the device shows as not-listening (see img1).
(My hope in doing this is that by setting openhab to recognise the device as not-listening it will not send messages that will get lost, and that with pressing enough times on the device I will awake it as much as needed to complete the initialisation)
I then run openhab in debug mode and I’m looking for the message pair (see snippet2) but the second message (completion) never appears. I press the device numerous times to wake it up but the initialization still doesn’t complete. The log file can be found here.
img1 (note that the Routing is still on although I think that since the device is battery based it is not routing - but I assume this does not affect the initialisation. Also, the Frequently listening is set to false)
No - the online not linked to the low level initialisation of the zwave device at all.
No - it won’t impact THIS device, but it will likely stop other devices in your network from working properly!
While this is fine for interests sake, you really need to stop this device from reporting incorrectly that it’s a mains powered unit. Even if you get this device initialising, I think it is fundimentally unlikely to ever work well no matter what you do to the binding.
I completely agree. I don’t illusion myself that a kind of hack will solve the problem at a whole. I am just trying to workaround the initialisation not completing, cause this is driving me crazy for almost a month now! (I tried everything else except to connect main power which I’ll do soon…)
I still have hard to understand how replacing the power source feeding through the same contacts (there isn’t another socket for main power) can be detected easily, but I’m not challenging you. I’ll get to it … (this is somewhat problematic long term, as I am plannning to use the device in a place without main power source)
The opposite, no? The device is battery based but advertises itself as listening (a feature associated with main power). I’m trying to convince the zwave binding to think that it is not-listening i.e. not main power unit.
Regardless, I get your message that tweaking the reporting is a cause for trouble.
While I can sympathise, my concern is that you might get the initialisation working, but then find that this device is causing other problems. As the listening flag is a protocol level flag, the controller will still think that it is permanently listening and available for routing and there is no way to solve this (as far as I know anyway). You might spend another month trying to sort that…
Well, the Aeon device definately does it, but it’s not fed through the same contacts - it has a USB power input.
In any case, the bottom line is that the listening flag needs to change, and my understanding is that since the protocol doesn’t allow dynamic changes, you need to exclude the device to change this.
No - it’s currently incorrectly reporting that it’s always listening which means it’s (incorrectly) reporting it’s a mains device.
But this is the problem - convincing the binding is probably quite easy - but you simply can’t convince the controller (as far as I know anyway). So no matter what the binding does, the controller will still think that this device is mains powered, and it’s the controller that decides routing etc.
