I never got my HSM100 (Express Control EZMotion 3in1) to work with OH either. But it may be a unrelated issue, it was so long time ago since I gave up, that I don’t remember anymore…
I decided to give it a go by pressing the button on the side for a NIF, I get;
17:45:12.769 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update request. Node information received.
17:45:12.770 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Node is ALIVE. Init stage is PING.
17:45:12.770 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNodeStatusEvent
17:45:12.770 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node Status event during initialisation - Node is ALIVE
17:45:12.770 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - PING: queue length(0), free to send(true)
17:45:12.770 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: loop - PING try 1: stageAdvanced(false)
17:45:12.770 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: PING - send NoOperation
17:45:12.770 [DEBUG] [ndclass.ZWaveNoOperationCommandClass] - NODE 53: Creating new message for command No Operation
17:45:12.770 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - queued packet. Queue length is 1
17:45:12.770 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
17:45:12.770 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
17:45:12.770 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 53: Node Status event - Node is ALIVE
17:45:12.770 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 08 00 13 35 01 00 25 87 72
17:45:12.770 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class MULTI_INSTANCE
17:45:12.770 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 53: Sending REQUEST Message = 01 08 00 13 35 01 00 25 87 72
17:45:12.771 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class MULTI_INSTANCE, endpoint null created
17:45:12.771 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update is adding command class MULTI_INSTANCE.
17:45:12.771 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Adding command class MULTI_INSTANCE to the list of supported command classes.
17:45:12.771 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class CONFIGURATION
17:45:12.771 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class CONFIGURATION, endpoint null created
17:45:12.771 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update is adding command class CONFIGURATION.
17:45:12.771 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Adding command class CONFIGURATION to the list of supported command classes.
17:45:12.771 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class WAKE_UP
17:45:12.771 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class WAKE_UP, endpoint null created
17:45:12.772 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update is adding command class WAKE_UP.
17:45:12.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Adding command class WAKE_UP to the list of supported command classes.
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class ASSOCIATION
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class ASSOCIATION, endpoint null created
17:45:12.772 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update is adding command class ASSOCIATION.
17:45:12.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Adding command class ASSOCIATION to the list of supported command classes.
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class BATTERY
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class BATTERY, endpoint null created
17:45:12.772 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update is adding command class BATTERY.
17:45:12.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Adding command class BATTERY to the list of supported command classes.
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class MANUFACTURER_SPECIFIC
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class MANUFACTURER_SPECIFIC, endpoint null created
17:45:12.772 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update is adding command class MANUFACTURER_SPECIFIC.
17:45:12.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Adding command class MANUFACTURER_SPECIFIC to the list of supported command classes.
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class NODE_NAMING
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class NODE_NAMING, endpoint null created
17:45:12.772 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update is adding command class NODE_NAMING.
17:45:12.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Adding command class NODE_NAMING to the list of supported command classes.
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class VERSION
17:45:12.772 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class VERSION, endpoint null created
17:45:12.772 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update is adding command class VERSION.
17:45:12.772 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 53: Adding command class VERSION to the list of supported command classes.
17:45:12.773 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 53: Is awake with 0 messages in the wake-up queue.
17:45:12.773 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveWakeUpEvent
17:45:12.773 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Wakeup during initialisation.
17:45:12.773 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - PING: queue length(1), free to send(false)
17:45:12.773 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - queued packet. Queue length is 1
17:45:12.773 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
17:45:12.773 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Set, dest=38, callback=134, payload=26 07 60 0D 01 01 25 01 FF
17:45:12.773 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationUpdate[0x49], type=Request[0x00], priority=High, dest=255, callback=0, payload=84 35 0E 04 21 01 60 31 70 84 85 80 72 77 86 EF 20
17:45:12.773 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationUpdate, callback id=134, expected=SendData, cancelled=false MISMATCH
17:45:13.773 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 53: No more messages, go back to sleep
17:45:13.773 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 53: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
Then I get a notification about a new thing, which I add. But it does not arrive into the ‘thing list’ under configuration.
I push the nif button again, and get;
18:21:14.989 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 53: Application update request. Node information received.
18:21:14.989 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 53: Is awake with 2 messages in the wake-up queue.
18:21:14.989 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveWakeUpEvent
18:21:14.989 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Wakeup during initialisation.
18:21:14.989 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - PING: queue length(1), free to send(false)
18:21:14.989 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - queued packet. Queue length is 1
18:21:14.989 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
18:21:14.989 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
18:21:14.989 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 08 00 13 35 01 00 25 ED 18
18:21:14.989 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=20, callback=235, payload=14 02 26 02
18:21:14.989 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 53: Sending REQUEST Message = 01 08 00 13 35 01 00 25 ED 18
18:21:14.989 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationUpdate[0x49], type=Request[0x00], priority=High, dest=255, callback=0, payload=84 35 0E 04 21 01 60 31 70 84 85 80 72 77 86 EF 20
18:21:14.990 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationUpdate, callback id=235, expected=ApplicationCommandHandler, cancelled=false MISMATCH
18:21:14.996 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
18:21:14.997 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18:21:14.997 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
18:21:14.997 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
18:21:14.997 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
18:21:14.997 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 53: Sent Data successfully placed on stack.
18:21:15.013 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 ED 00 00 02 04
18:21:15.013 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18:21:15.013 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 ED 00 00 02 00 00 0A
18:21:15.013 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 ED 00 00 02 00 00 0A
18:21:15.013 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=ED 00 00 02
18:21:15.013 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 53: SendData Request. CallBack ID = 237, Status = Transmission complete and ACK received(0)
18:21:15.014 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Poll, dest=53, callback=237, payload=35 01 00
18:21:15.014 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=ED 00 00 02
18:21:15.014 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=237, expected=SendData, cancelled=false transaction complete!
18:21:15.014 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - PING: Transaction complete (SendData:Request) success(true)
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - checking initialisation queue. Queue size 1.
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - message removed from queue. Queue size 0.
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - PING: queue length(0), free to send(true)
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: loop - PING try 2: stageAdvanced(false)
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - advancing to DETAILS
18:21:15.014 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInitializationStateEvent
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: loop - DETAILS try 0: stageAdvanced(true)
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: received RequestNodeInfo
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - advancing to INCLUSION_START
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: loop - INCLUSION_START try 0: stageAdvanced(true)
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: Unknown node state INCLUSION_START encountered.
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - advancing to IDENTIFY_NODE
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: loop - IDENTIFY_NODE try 0: stageAdvanced(true)
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: PROTOINFO - send IdentifyNode
18:21:15.014 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - queued packet. Queue length is 1
18:21:15.015 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 2. Queue={}
18:21:15.015 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
18:21:15.015 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 53: Response processed after 25ms/4984ms.
18:21:15.015 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
18:21:15.015 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 08 00 13 35 01 00 25 EF 1A
18:21:15.015 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 53: Sending REQUEST Message = 01 08 00 13 35 01 00 25 EF 1A
18:21:15.022 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
18:21:15.022 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18:21:15.022 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
18:21:15.022 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
18:21:15.022 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
18:21:15.022 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 53: Sent Data successfully placed on stack.
18:21:15.038 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 EF 00 00 02 06
18:21:15.038 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18:21:15.039 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 EF 00 00 02 00 00 08
18:21:15.039 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 EF 00 00 02 00 00 08
18:21:15.039 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=EF 00 00 02
18:21:15.039 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 53: SendData Request. CallBack ID = 239, Status = Transmission complete and ACK received(0)
18:21:15.039 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=53, callback=239, payload=35 01 00
18:21:15.039 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=EF 00 00 02
18:21:15.039 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=239, expected=SendData, cancelled=false transaction complete!
18:21:15.039 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
18:21:15.039 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - IDENTIFY_NODE: Transaction complete (SendData:Request) success(true)
18:21:15.039 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - checking initialisation queue. Queue size 1.
18:21:15.039 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 53: Response processed after 24ms/4984ms.
18:21:15.039 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
18:21:15.039 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 35 02 84 08 25 EE 95
18:21:15.039 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 53: Sending REQUEST Message = 01 09 00 13 35 02 84 08 25 EE 95
18:21:15.046 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
18:21:15.046 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18:21:15.046 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
18:21:15.046 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
18:21:15.046 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
18:21:15.047 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 53: Sent Data successfully placed on stack.
18:21:15.063 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 EE 00 00 02 07
18:21:15.063 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18:21:15.064 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 EE 00 00 02 00 00 09
18:21:15.064 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 EE 00 00 02 00 00 09
18:21:15.064 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=EE 00 00 02
18:21:15.064 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 53: SendData Request. CallBack ID = 238, Status = Transmission complete and ACK received(0)
18:21:15.064 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=53, callback=238, payload=35 02 84 08
18:21:15.064 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=EE 00 00 02
18:21:15.064 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=238, expected=SendData, cancelled=false transaction complete!
18:21:15.064 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
18:21:15.064 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - IDENTIFY_NODE: Transaction complete (SendData:Request) success(true)
18:21:15.064 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - checking initialisation queue. Queue size 1.
18:21:15.064 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 53: Went to sleep
18:21:15.064 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 53: Is sleeping
18:21:15.064 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 53: Response processed after 25ms/4984ms.
18:21:15.064 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
18:21:15.065 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 41 35 8F
18:21:15.065 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 41 35 8F
18:21:15.066 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 01 41 51 8C 00 04 21 01 4F
18:21:15.067 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
18:21:15.067 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 01 41 51 8C 00 04 21 01 4F
18:21:15.067 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 01 41 51 8C 00 04 21 01 4F
18:21:15.067 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=IdentifyNode[0x41], type=Response[0x01], priority=High, dest=255, callback=0, payload=51 8C 00 04 21 01
18:21:15.067 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: ProtocolInfo
18:21:15.067 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Listening = false
18:21:15.067 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Routing = true
18:21:15.067 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Beaming = false
18:21:15.067 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Version = 2
18:21:15.067 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: FLIRS = false
18:21:15.068 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Security = false
18:21:15.068 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Max Baud = 40000
18:21:15.068 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Basic = Routing Slave
18:21:15.068 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Generic = Multi-Level Sensor
18:21:15.068 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 53: Specific = Routing Multilevel Sensor
18:21:15.068 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class NO_OPERATION
18:21:15.068 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class NO_OPERATION, endpoint null created
18:21:15.068 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Version = 1, version set. Enabling extra functionality.
18:21:15.068 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class BASIC
18:21:15.068 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class BASIC, endpoint null created
18:21:15.068 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Creating new instance of command class SENSOR_MULTILEVEL
18:21:15.068 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 53: Command class SENSOR_MULTILEVEL, endpoint null created
18:21:15.068 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=IdentifyNode[0x41], type=Request[0x00], priority=High, dest=255, callback=0, payload=35
18:21:15.068 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=IdentifyNode[0x41], type=Response[0x01], priority=High, dest=255, callback=0, payload=51 8C 00 04 21 01
18:21:15.068 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=IdentifyNode, callback id=0, expected=IdentifyNode, cancelled=false transaction complete!
18:21:15.068 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
18:21:15.068 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - IDENTIFY_NODE: Transaction complete (IdentifyNode:Request) success(true)
18:21:15.068 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - checking initialisation queue. Queue size 1.
18:21:15.069 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - message removed from queue. Queue size 0.
18:21:15.069 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - IDENTIFY_NODE: queue length(0), free to send(true)
18:21:15.069 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: loop - IDENTIFY_NODE try 1: stageAdvanced(false)
18:21:15.069 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - advancing to MANUFACTURER
18:21:15.069 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInitializationStateEvent
18:21:15.069 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: loop - MANUFACTURER try 0: stageAdvanced(true)
18:21:15.069 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer: MANUFACTURER - send ManufacturerSpecific
18:21:15.069 [DEBUG] [WaveManufacturerSpecificCommandClass] - NODE 53: Creating new message for command MANUFACTURER_SPECIFIC_GET
18:21:15.069 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 53: Node advancer - queued packet. Queue length is 1
18:21:15.069 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 53: Putting message SendData in wakeup queue.
Does this look like the same issue?
I haven’t done any reset or removal of the device, it has been located by the stick since before summer, when I gave up on it.
