Hi, I moved my Homematic dominated infrastructure to CCU3, because I need to update the underlaying system on my rasperrymatic due to be able to connect newly bought sensors (they did not connect to CCU2 - firmware update required on raspberrymatic).
After I updated the firmware I realized, that my current OH 2.3 does not connect to a Homematic CCU2. The solution from other users here in the community was to migrate to a SNAPSHOT version 2.4. So I did. The CCU3 was connected fine, but still some errors occures for some in past well working sensors - channel not found. I’ve red about timing issues during startup and decided, to move the installation to a much faster Intel NUC Box.
So my basic plan was, to install debian 9 stretch on this box and install OH from nightly repo (as I need at least 2.4) and migrate my installation using backup on the pi, copy the file to the new NUC and restore it.
Unfortunatly I received OH 2.5 from the snapshot repo. Backup and restore are done without errors.
But finaly nothing from my installation appeared in the new system. No Binding, No Thing, No Item, No nothing.
I am using mostly files to configure services, things and items and in seldom cases the Discovery option via Paper UI.
What I’am doing wrong? I just want to copy all my setup / config to a new Box to overcome this timing problems.
Restore is looking like this:
openHAB 2.x.x restore script
Using '/etc/openhab2' as conf folder...
Using '/var/lib/openhab2' as userdata folder...
Making Temporary Directory
Extracting zip file to temporary folder.
Backup Information:
Backup Version | 2.5.0-SNAPSHOT (You are on 2.5.0-SNAPSHOT)
Backup Timestamp | 18_12_17-22_35_59
Config belongs to user | openhab
from group | openhab
Your current configuration will become owned by openhab:openhab.
Any existing files with the same name will be replaced.
Any file without a replacement will be deleted.
Okay to Continue? [y/N]: y
Moving system files in userdata to temporary folder
Deleting old userdata folder...
Restoring system files in userdata...
Deleting old conf folder...
Restoring openHAB with backup configuration...
Deleting temporary files...
Backup successfully restored!
Booth systems running on debian. RPI is running Zulu Java and the NUC OpenJDK.
Can anyone help me in this special case please?
Best regards
Kay
