Hi everyone is it possible to move OH’s main folder so it can run from and write to a different drive my c drive gets busy sometimes this seems to make OH freeze (maby OH freezing is unrelated)
I did try to copy the main folder the karaf would not start so im not sure if this is possible
openHAB should start from wherever it was unzipped. It may be that there are default paths which have to be changed in configuration.
Please ensure that no spaces appear in the path, so best practice is D:\openHAB2\, not "C:\Program Files\openHAB2\" …
I had issues moving a previously unzipped and running version of OH on my C drive to another drive.
I spent a couple of hours looking for where the mapping could be stored and wound up installing a fresh version of OH on the second drive and migrating all of my setting over to the new installation.
If you determine what needs to be changed, please post it back here so we have a reference to follow.
Please keep in mind, that there is no “Windows openHAB version” at all, but openHAB can be executed without any changes from different platforms. Of course there are a few settings in configuration files, which will differ, when it comes to folders and paths, and there is a start.bat for Windows instead of start.sh for unix-like systems, but this is only for startup.
i will have a look see if i can find whats stopping it from running im planning on trying to move all my paperui created things and items to text based files soon this would make it easier to just move
