So when i first started using openhab i installed it on an older laptop to run my smarthome system.
I have expanded from just openhab to several other things that is running from the same laptop. But recently i came across a cheap xeon server and thought i would migrate to that. The problem is, i cant simply remove the hdd from the laptop and chuck it in the xeon machine.
Simply, because the laptop hdd has a stupid power connector. Needs an adapter to get power from normal power connectors. But i have a spare ssd i can use, so my question is:
Can i completely backup the ubuntu system running all of my stuff and move it to the other ssd?
The laptop does not have any possibilities of connecting a second harddrive, usb hdd would be possible but i do not have that on hand.
Any other ways of doing this?
