Platform information:
from windows machine, to raspi 3 openhabian with OH 2.2.0 -
Issue of the topic: I have copied most of userdata and conf folder last year from windows machine to openhabian, now it looks my SD card got corrupt, so I installed on new SD card and copied from latest backup (copied userdata and conf folder) and I noticed this log entry that looks like from Windows machine configuration.
If logs where generated please post these here using code fences:
2018-05-26 08:23:08.539 [WARN ] [org.apache.felix.fileinstall ] - D:\OpenHab/addons does not exist, please create it.
2018-05-26 08:23:08.565 [WARN ] [org.apache.felix.fileinstall ] - Root path does not exist: /var/lib/openhab2/D:\OpenHab/addons
2018-05-26 08:23:08.569 [WARN ] [org.apache.felix.fileinstall ] - C:\OpenHab/addons does not exist, please create it.
2018-05-26 08:23:08.574 [WARN ] [org.apache.felix.fileinstall ] - Root path does not exist: /var/lib/openhab2/C:\OpenHab/addons
2018-05-26 08:23:08.579 [WARN ] [org.apache.felix.fileinstall ] - /Users/myusername/openHAB/addons does not exist, please create it.
2018-05-26 08:23:08.582 [ERROR] [org.apache.felix.fileinstall ] - Cannot create folder /Users/myusername/openHAB/userdata/tmp/bundles. Is the folder write-protected?
2018-05-26 08:23:08.587 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.cm.ManagedServiceFactory, id=37, bundle=8/mvn:org.apache.felix/org.apache.felix.fileinstall/3.5.8]: Unexpected problem updating configuration org.apache.felix.fileinstall.28fa93d1-046a-43f0-9e7b-01be7e568683
java.lang.RuntimeException: Cannot create folder: /Users/myusername/openHAB/userdata/tmp/bundles
at org.apache.felix.fileinstall.internal.DirectoryWatcher.prepareDir(DirectoryWatcher.java:638) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.prepareTempDir(DirectoryWatcher.java:618) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.<init>(DirectoryWatcher.java:175) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.FileInstall.updated(FileInstall.java:247) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.fileinstall.internal.FileInstall$ConfigAdminSupport$Tracker.updated(FileInstall.java:377) [8:org.apache.felix.fileinstall:3.5.8]
at org.apache.felix.cm.impl.helper.ManagedServiceFactoryTracker.updated(ManagedServiceFactoryTracker.java:159) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.helper.ManagedServiceFactoryTracker.provideConfiguration(ManagedServiceFactoryTracker.java:93) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceFactoryUpdate.provide(ConfigurationManager.java:1640) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceFactoryUpdate.run(ConfigurationManager.java:1582) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141) [7:org.apache.felix.configadmin:1.8.16]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109) [7:org.apache.felix.configadmin:1.8.16]
what can I do to remove that error permanently? thanks in advance
