Hello, I have moved root to USB because of SD card problem. It have 0 disk space left and OH is stopped working. I moved to USB using openhabian-config tool and everything is no longer running. However, since I still able to access every configuration file of my services (I use influx+grafana, and mosquitto) I want to go back to SD. The same SD as before.
I have read a topic about moving root to USB and every command used, but I do not know how to go back to SD as I am Linux noob. Thanks in advance
