Issue of the topic: after following this openhab 2.5.8 MPD binding docs, I do not see any MPD things in paper UI, and MPD items (now playing, etc) is not shown on basic UI either
Thank you for your pointer. However, the mpd.items is actually loaded normally as I can see in sitemap that showing Group members of Group_VolumioLiving.
Even after I fixed it, the item state is not loaded. No error message on error log after saving the mpd.items (currently set to INFO)
Assuming the binding is installed, that would suggest your xxx.things file is not loaded. Perhaps you introduced an error when editing. What does your openhab.log say about it?
If the addon is active, I would try to temporarily add an mpd thing using the Paper UI just to exclude problems with the things file. If the thing is visible, online and the channels work, you can go back to the textual configuration.
and this is the paperUI result on thing and item using channel “Media Title” generated from paperUI where I have triple checked IP address and music is actually playing:
It was a cache and tmp folder problem. Openhabian shows 2.5.8 on ssh login, but welcome page (openhabian.local:8080) shows 2.5.7. After I cleared it, paper UI shows the item. Sorry for not informing it on previous post.
What is the status of the thing? Is it online? If it is not, you can find a more detailed status message, if you navigate to configuration -> thing -> mpd thing. This should give you a hint what the problem might be.
If the thing is online, I need log files with the log level set to DEBUG or TRACE to further investigate your problem. Use the console to set the log level:
openhab> log:set TRACE org.openhab.binding.mpd
According to https://volumio.org/technical-overview, volumio uses an MPD Emulation Interface, which may not be fully compatibe with the MPD protocol. I haven’t checked that in detail and I also didn’t try volumio myself. This might be the reason, why the channels are not updated.
Thing mpd:mpd:music “Volumio” @ “Livingroom” [ ipAddress=“192.168.1.77”, port=6600 ]
Apparently this is wrong syntax, it should not have “Thing” in things file. Now the thing is available in paperUI. It wasn’t there back then. After reinstalling openhab and updating things file, it shows up.
I don’t think log below will help, but here it is:
2020-10-29 00:21:07.443 [INFO ] [server.session.ServerUserAuthService] - Session openhab@/127.0.0.1:55200 authenticated
2020-10-29 00:21:17.306 [INFO ] [port.EventAdminConfigurationNotifier] - Sending Event Admin nofification (configuration successful) to org/ops4j/pax/logging/Configuration
2020-10-29 00:22:07.497 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'stop' at position -1
2020-10-29 00:22:09.313 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'play' at position -1
2020-10-29 00:22:10.716 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'play' at position -1
2020-10-29 00:22:10.927 [me.event.InboxUpdatedEvent] - Discovery Result with UID 'miio:generic:036E06C8' has been updated.
2020-10-29 00:22:11.348 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'play' at position -1
2020-10-29 00:32:10.890 [me.event.InboxUpdatedEvent] - Discovery Result with UID 'miio:generic:036E06C8' has been updated.
2020-10-29 00:33:02.925 [me.event.InboxUpdatedEvent] - Discovery Result with UID 'mihome:sensor_plug:7811dc64e075:158d000282b27c' has been updated.
2020-10-29 00:40:28.635 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'next' at position -1
2020-10-29 00:40:29.955 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'play' at position -1
2020-10-29 00:40:30.529 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'previous' at position -1
2020-10-29 00:40:31.136 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'pause' at position -1
2020-10-29 00:40:34.442 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'stop' at position -1
2020-10-29 00:40:35.111 [DEBUG] [nternal.protocol.MPDConnectionThread] - insert command 'play' at position -1
2020-10-29 00:40:39.960 [me.event.InboxUpdatedEvent] - Discovery Result with UID 'mihome:sensor_plug:7811dc64e075:158d000282b27c' has been updated.
It can be controlled with Android mpd clients, Kodi mpd client, etc. I don’t see why it can’t be read nor controlled by OH.
You are right, the log doesn’t help. Unfortunately it is missing relevant information. The log from the start of the binding/thing is required. At startup the connection to the mpd server is established and a line with “…opening connection to…” appears. Can you create an mpd thing in PaperUI and send the full log?
Furthermore, I still don’t know whether the thing is online or not. If the thing appears in PaperUI this does not yet mean the thing is online.
