I’ve been using MPD binding with OH2 for quite a while now, my configuration follows the official docs and is using Switch items for controlling the player.
It was working fine in all the UIs till the recent iOS update, which started using a different widget for Switches:
No, doesn’t help.
To clarify: it works fine in PaperUI and Android, only an iOS app uses a widget that doesn’t allow to click the same switch position twice.
Thanks for the build. Widget still looks the same. Previous acts interesting now: it sends the command, becomes highlighted and then selection slides to the right, e.g. Next becomes selected again on its own. This way I can press Previous multiple times, but can’t use Next at all.
Can include the video if needed.
Build 2.2.50
