I am running into an error updating integer types in the new MQTT 2.0 binding with a device using the homie convention. I have no problems with string types.
Rule looks like this:
rule "Track Time Changed"
Item ChromecastStatusCurrentTime changed
val trackPosition = (ChromecastStatusCurrentTime.state as DecimalType).intValue
logInfo("Nuvo", "Sending new track position {}", trackPosition)
//Nuvo_Source_5_Track_Position.sendCommand(new Integer(trackPosition))
Nuvo_Source_5_Track_Position.sendCommand(50)
note I simplified it to just send 50, in case my conversion was an issue.
Item is defined like this:
Number Nuvo_Source_5_Track_Position {channel="mqtt:homie300:mosquitto:nuvo:source5#position"}
I see the following in the log when an update happens:
2019-01-12 13:34:33.943 [DEBUG] [eneric.internal.generic.ChannelState] - Format pattern incorrect for mqtt:homie300:mosquitto:nuvo:source5#position
java.util.IllegalFormatConversionException: d != java.lang.String
at java.util.Formatter$FormatSpecifier.failConversion(Formatter.java:4302) ~[?:?]
at java.util.Formatter$FormatSpecifier.printInteger(Formatter.java:2793) ~[?:?]
at java.util.Formatter$FormatSpecifier.print(Formatter.java:2747) ~[?:?]
at java.util.Formatter.format(Formatter.java:2520) ~[?:?]
at java.util.Formatter.format(Formatter.java:2455) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.generic.ChannelState.publishValue(ChannelState.java:312) [230:org.eclipse.smarthome.binding.mqtt.generic:0.10.0.oh240]
at org.eclipse.smarthome.binding.mqtt.generic.internal.handler.AbstractMQTTThingHandler.handleCommand(AbstractMQTTThingHandler.java:119) [230:org.eclipse.smarthome.binding.mqtt.generic:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor121.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy222.handleCommand(Unknown Source) [230:org.eclipse.smarthome.binding.mqtt.generic:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor120.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
2019-01-12 13:34:33.949 [DEBUG] [nal.handler.AbstractMQTTThingHandler] - Successfully published value 50 to topic homie/nuvo/source5/position
Looking at the code, it seems to indicate that it is trying to convert a number placeholder in a format with a string value… The value does actually get published, after the exception.
@David_Graeff Is this working as designed, or is this an issue?
val Number trackPosition = (ChromecastStatusCurrentTime.state as DecimalType).intValue
Nuvo_Source_5_Track_Position.sendCommand(trackPosition)
//Nuvo_Source_5_Track_Position.sendCommand(50)
I agree that the error message should be a better one instead of showing the exception stack trace.
You have changed the formatter parameter from “%s” to something else apparently, I have no other explanation.
The formatter takes an input and does what ever the “format” arguments tells him to do. And “%s” basically says, make a string out of everything. And that works in Java via the implicit .toString() method on every object.
There is an automated test suite that checks publish/receive of string and number channels and that test suite almost guarantees that this functionality works and no developer can break it on accident.
It is failing because the format is of type “%d” which means: “I only accept integers”, and on line 304 the value is being stored in a String which is then passed to the format command.
Nah, the input is always a string. The formatter pattern “%d” should be more like “output an integer”. Otherwise the entire formatter API wouldn’t make sense.
public class MyClass {
public static void main(String args[]) {
java.util.Formatter formatter = new java.util.Formatter();
System.out.println(formatter.format("%d",5));
System.out.println("=============");
System.out.println(formatter.format("%d",Integer.toString(5)));
5
Exception in thread "main" java.util.IllegalFormatConversionException: d != java.lang.String
at java.base/java.util.Formatter$FormatSpecifier.failConversion(Formatter.java:4421)
at java.base/java.util.Formatter$FormatSpecifier.printInteger(Formatter.java:2936)
at java.base/java.util.Formatter$FormatSpecifier.print(Formatter.java:2890)
at java.base/java.util.Formatter.format(Formatter.java:2671)
at java.base/java.util.Formatter.format(Formatter.java:2607)
at MyClass.main(MyClass.java:6)
Command exited with non-zero status 1
A large part of what the formatter does is convert objects into string representations of those objects.
Oh. So I had a full black-out while coding that piece of the binding and actually need a parse-and-output like API, that complies to what I have written in the binding documentation.
