I run OH 2.4.0 Release Build and am testing @cweitkamp’s new Hue binding with support for Hue Tap and Hue Profiles (see here). When removing the oh240 version of the Hue binding and installing the latest test version in the addons
directory I had some errors related to dependency of mqttgeneric with hue binding. I temporary removed the mqtt and mqttgeneric bindings to test the hue binding. When adding the mqtt bindings again, the following errors are in the log file:
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqttgeneric': Error restarting bundles:
Could not resolve module: org.eclipse.smarthome.binding.hue [224]
Another singleton bundle selected: osgi.identity; type="osgi.bundle"; version:Version="0.11.0.201901011457"; osgi.identity="org.eclipse.smarthome.binding.hue"; singleton:="true"
It also installed the original hue binding (oh240 version) alongside the test version (status: Installed).
@David_Graeff Is there a dependency between mqtt and hue binding? Or am I missing something else?
