I’ve just upgraded to OpenHab 2.4 running on OpenHabian (rPi 3+) and I’ve had to remove the MQTT1 binding and look at using the MQTT 2 binding - probably about time!
I’ve managed to get most things working again but I’m having problems with my 433Mhz switchable sockets. I have another rPi monitoring a MQTT topic called rff_trx and it will broadcast over 433mhz any code sent via MQTT.
Within openHab I previously had this item configured to post to an OpenHab MQTT1 configured topic
Switch Socket_one "Socket 1" [Lighting] {mqtt=">[mqtt:topic:cf9a9121:rff_trx:ON:1381717],>[mqtt:topic:cf9a9121:rff_trx:OFF:1381716]"}
I can’t work out how to get this working with the new MQTT2 binding. I have a working Broker thing (mqtt:broker:fb711156) and I’ve tested it. Is it possible to send two different codes from a single switch directly from the Items file?
