openHAB version: 2.4. New MQTT 2.4 Binding
Issue of the topic:
The Xiaomi Water Leak sensor publishes a tag “water_leak” with “true” or “false”.
I don´t get the transformation to work to a “contact” .
Hopefully somebody can help.
Thing configuration related to the issue
Bridge mqtt:broker:myAuthentificatedBroker "Mosquitto MQTT Broker" @ "MQTT" [ host="localhost", secure=false, username="stefan", password="xxx", clientID="openHAB2" ]
//Water Sensors
Thing topic XiaomiWaterSensor1 "Wassersensor" {
Channels:
Type contact : contact "Contact" [ stateTopic="zigbee2mqtt/XiaomiWaterSensor1", transformationPattern="JS:LeakContact.js"]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/XiaomiWaterSensor1", transformationPattern="JSONPATH:$.voltage"]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/XiaomiWaterSensor1", transformationPattern="JSONPATH:$.battery"]
The LeakContact.js file is stored under the folder transformation.
LeakContact.js has the following code:
(function(x){
var result = "";
var json = JSON.parse(x);
if (json.contact)
result="CLOSED";
else
result="OPEN";
return result;
})(input)
Item File:
Contact LeakageMetering1 "Wasser ausgetreten [%s]" <water> {channel="mqtt:topic:myAuthentificatedBroker:XiaomiWaterSensor1:contact"}
Logfile:
Command '{"battery":86,"voltage":2975,"linkquality":0,"water_leak":true}' not supported by type 'OpenCloseValue': No enum constant org.eclipse.smarthome.core.library.types.OpenClosedType.{"battery":86,"voltage":2975,"linkquality":0,"water_leak":true}
2019-03-27 14:37:49.202 [WARN ] [l.generic.ChannelStateTransformation] - Executing the JS-transformation failed: An error occurred while loading script.
