I have a problem with the things file, I configurate a mqtt broker and a test thing. The broker and the thing works fine with some typs like switch, dimmer and string. But the type color doesn´t work. I´ve the configuration from [https://www.openhab.org/blog/2018-12-16-mqtt-arrives-in-the-modern-openhab-2-x-architecture.html](http://openhab blog)
Bridge mqtt:broker:myUnsecureBroker [ host="192.168.0.42", secure=false ]
Thing mqtt:topic:mything {
Channels:
Type switch : lamp "Kitchen Lamp" [ stateTopic="lamp/enabled", commandTopic="lamp/enabled/set" ]
Type switch : fancylamp "Fancy Lamp" [ stateTopic="fancy/lamp/state", commandTopic="fancy/lamp/command", on="i-am-on", off="i-am-off" ]
Type string : alarmpanel "Alarm system" [ stateTopic="alarm/panel/state", commandTopic="alarm/panel/set", allowedStates="ARMED_HOME,ARMED_AWAY,UNARMED" ]
Type color : lampcolor "Kitchen Lamp color" [ stateTopic="lamp/color", commandTopic="lamp/color/set", rgb=true ]
Type dimmer : blind "Blind" [ stateTopic="blind/state", commandTopic="blind/set", min=0, max=5, step=1 ]
I get a exception in Paper UI for the thing: OFFLINE - CONFIGURATION_ERROR Remove and recreate: mqtt:topic:wohnzimmerTestLED:lampcolor
I´ve search for hours but it looks like I´m the only one with the problem
I hope someone can help me
Thank you in advance
Lukas
