thear all i’m trying to read the values of the following MQTT string using Jsonpath, I need the target_t value of 27 in the example, in thernostats section
"device": {
"type": "SHTRV-01",
"mac": "60A423D7EB2A",
"hostname": "shellytrv-60A423D7EB2A",
"num_outputs": 0
"wifi_ap": {
"enabled": false,
"ssid": "shellytrv-60A423D7EB2A"
"wifi_sta": {
"enabled": true,
"ssid": "merola-Alice",
"ipv4_method": "static",
"ip": "192.168.0.221",
"gw": "192.168.0.1",
"mask": "255.255.254.0",
"dns": "8.8.8.8"
"mqtt": {
"enable": true,
"server": "192.168.0.90:1883",
"user": null,
"id": "shellytrv-60A423D7EB2A",
"clean_session": true,
"max_qos": 0,
"retain": false,
"update_period": 60
"sntp": {
"server": "time.google.com",
"enabled": true
"login": {
"enabled": false,
"unprotected": false,
"username": "xxxxx",
"default_username": "xxxxxx"
"pin_code": "",
"name": null,
"fw": "20211223-144805/v2.1.0@d30148ec",
"discoverable": true,
"build_info": {
"build_id": "20211223-144805/v2.1.0@d30148ec",
"build_timestamp": "2021-12-23T14:48:05Z",
"build_version": "2021122314"
"cloud": {
"enabled": false
"coiot": {
"enabled": false,
"update_period": 3600,
"peer": ""
"timezone": "Europe/Rome",
"lat": 41.95967,
"lng": 12.46035,
"tzautodetect": true,
"tz_utc_offset": 3600,
"tz_dst": false,
"tz_dst_auto": true,
"time": "07:38",
"child_lock": false,
"display": {
"brightness": 7,
"flipped": false
"hwinfo": {
"hw_revision": "dev-prototype",
"batch_id": 0
"sleep_mode": {
"period": 60,
"unit": "m"
"thermostats": [
"target_t": {
"enabled": true,
"value": 27,
"units": "C"
"schedule": false,
"schedule_profile": 5,
"schedule_profile_names": [
"Livingroom",
"Livingroom 1",
"Bedroom",
"Bedroom 1",
"Holiday"
"schedule_rules": [
"0000-0123456-10"
"temperature_offset": 0,
"ext_t": {
"enabled": false
in my things file I have the following line
Type number : temperatura_target [ stateTopic="shellies/shellytrv-60A423D7EB2A/settings", transformationPattern="JSONPATH:$.thermostats.target_t.value", commandTopic="shellies/shellytrv-60A423D7EB2A/thermostat/0/command/target_t"]
in the items file i have the following line
Number Termovalvola_studio_target_t "Target T [%.1f °C]" (gall) {channel="mqtt:topic:mosquitto:shellytrv-60A423D7EB2A:temperatura_target"}
what is wrong?
I’m able to read all other values, for example mqtt server or wifi_sta ssid…
thanks in advance for your help.
Livio
