I changed the Openhab MQTT.config file to make the changes to the user name. The arduino also is not connecting to the Broker now either
pi@MQTT:~ $ mosquitto_sub -h localhost -t # -v
Is the commands where I’m getting the connection refused.
did you restart the pi?
yes both Openhab and MQTT broker
still just getting a refused connection
MAybe you should have a look to the log file. Best to do is open the openhab logviewer (frontail) via web-browser on http://:9001 or via ssh or local Shell (tail -f /var/log/openhab2/openhab.log)
At the restart of openhab, you should see if mqtt is loading and if openhab is connecting to the Server…
Andreas
Guys here is the log file the MQTT service is launching but not connecting. Not sure where the broker or connections are coming from. The MQTT.Confg is mosquitto.
Any help would be great. Cant get MQTT to connect.
2018-02-16 20:24:06.083 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to en_US, Location set to null, Time zone set to US/Mountain
2018-02-16 20:24:06.608 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-02-16 20:24:07.730 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.3.2:8080
2018-02-16 20:24:07.741 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.3.2:8443
2018-02-16 20:24:15.417 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
2018-02-16 20:24:21.893 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'Accent_Lighting.items' has errors, therefore ignoring it: [2,1]: missing EOF at '#'
2018-02-16 20:24:25.388 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-02-16 20:24:28.720 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'home.rules'
2018-02-16 20:24:29.479 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'Home.sitemap', using it anyway:
Frames must not contain other frames
2018-02-16 20:24:29.486 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Home.sitemap'
2018-02-16 20:24:29.876 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.things'
2018-02-16 20:24:32.352 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-02-16 20:24:32.463 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-02-16 20:24:32.555 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-02-16 20:24:32.856 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
2018-02-16 20:24:32.945 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-02-16 20:24:32.948 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:24:33.264 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection '<broker>'
2018-02-16 20:24:33.287 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:24:33.322 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
org.eclipse.paho.client.mqttv3.MqttException: Connection lost
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:146) [210:org.openhab.io.transport.mqtt:1.11.0]
at java.lang.Thread.run(Thread.java:745) [?:?]
Caused by: java.io.EOFException
at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:65) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:107) ~[?:?]
... 1 more
2018-02-16 20:24:33.355 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:24:33.356 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:24:33.419 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-02-16 20:24:43.379 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:24:43.424 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:24:43.437 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:24:43.439 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:24:53.451 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:24:53.484 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:24:53.498 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:24:53.500 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:25:03.502 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:25:03.532 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:25:03.546 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:25:03.548 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:25:13.550 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:25:13.584 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:25:13.596 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:25:13.598 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:25:23.600 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:25:23.651 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:25:23.665 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:25:23.667 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:25:33.669 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:25:33.702 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:25:33.726 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:25:33.729 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:25:43.733 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:25:43.746 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:25:43.753 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:25:43.754 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:25:53.756 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:25:53.791 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:25:53.810 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:25:53.813 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:26:03.816 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:26:03.840 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:26:03.854 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:26:03.856 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:26:13.859 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:26:13.886 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:26:13.900 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:26:13.902 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:26:23.906 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:26:23.944 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:26:23.963 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:26:23.966 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:26:33.969 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:26:34.004 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:26:34.018 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:26:34.020 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:26:44.028 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:26:44.051 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:26:44.060 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:26:44.061 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:26:54.063 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:26:54.093 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:26:54.116 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:26:54.128 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:27:04.133 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:27:04.162 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:27:04.171 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:27:04.172 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:27:14.174 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:27:14.196 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:27:14.209 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:27:14.211 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:27:24.213 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:27:24.237 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:27:24.298 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:27:24.300 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:27:34.303 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:27:34.327 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:27:34.339 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:27:34.341 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:27:44.342 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:27:44.367 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:27:44.385 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:27:44.387 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
2018-02-16 20:27:54.390 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'broker'
2018-02-16 20:27:54.426 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:27:54.441 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'mosquitto' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:27:54.443 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mosquitto'
2018-02-16 20:28:04.446 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
2018-02-16 20:28:04.496 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to broker was lost
... 1 more
2018-02-16 20:28:04.518 [ERROR] [t.mqtt.internal.MqttBrokerConnection] - MQTT connection to 'broker' was lost: Connection lost : ReasonCode 32109 : Cause : null
2018-02-16 20:28:04.520 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'broker'
