Hello guys!
Im facing a isse with MQTT binding after restarting the computer:
OpenHAB 2.5.3
MQTT binding 2.5.3
3 Tasmota Sonoff
All instalation was thru Paper UI (if it helps)
Error : OFFLINE - CONFIGURATION_ERROR @text/offline.notextualconfig
if I disable and enable the thing on Paper Ui i get this:
15:09:50.346 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:cc70be1d' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
15:09:50.361 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:cc70be1d' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
15:09:50.361 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:658b4c37' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
15:09:50.377 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:658b4c37' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
15:09:50.377 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:72652b1e' changed from OFFLINE (BRIDGE_OFFLINE) to UNINITIALIZED
15:09:50.408 [WARN ] [ng.mqtt.handler.AbstractBrokerHandler] - Trying to dispose handler mqtt:systemBroker:embedded-mqtt-broker but connection is already null. Most likely this is a bug.
15:09:50.408 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:72652b1e' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
15:09:50.424 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:systemBroker:embedded-mqtt-broker' changed from OFFLINE (CONFIGURATION_ERROR): @text/offline.notextualconfig to UNINITIALIZED
15:09:50.439 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:systemBroker:embedded-mqtt-broker' changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
15:09:50.455 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:cc70be1d' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
15:09:50.455 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:658b4c37' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
15:09:50.486 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:topic:72652b1e' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
I dont know if there is any other information I can add.
i did try to do some reserch… but I prefer to get some directions before messing up.
Thanks in advance for the help
