MQTT Binding and SSL
Step 1 success! I’m able to connect an MQTT client to my 8883 listener with the Certbot certificates!
This listener config line was wrong:
listener 1883 localhost
adding the host at the end binds all traffic on the port to have to come from that host only… which obviously is not what I want. The line needs to be:
listener 1883
Now on to OwnTracks, then openHAB, then ACLs.
Mike
P.S. Did you hear me scream in elation? :wink:
P.P.S. Symlinks worked.
@vzorglub
Many thanks for the excellent guide.
I have the impression that the following command is wrong.
sudo keytool -import -alias myopenhab -file addtrustexternalroot.cert -storetype JKS -keystore.jsk
In any case it didnt work for me. What worked is
sudo keytool -import -alias myopenhab -file addtrustexternalroot.cert -storetype JKS -keystore truststore.jks
And I confirm that it works ! I just used it to get some sensor values from “The things network” based on LoRaWAN sensors located 500 meters away !
Christos (or anyone), how did you get your addtrustexternalroot.cert file? When I go to the link in the instructions (https://support.comodo.com/index.php?/Knowledgebase/Article/View/854/75/root-addtrustexternalcaroot) it downloads a addtrustexternalroot.crt file. the extension is different, cert vs crt.
Do be honest it was a while ago and I may have made a mistake and it was crt and not cert
You need to generate a jks file from it in the next step, have you tried this with your crt file?
I think that it does not really matter what the extension is. It is the content that matters. You can put whatever extension you like so crt should be ok
when I run this and enter my password:
keytool -import -alias myopenhab -file /home/pi/Desktop/temp/ca.crt -storetype JKS -keystore keystore.jks
I get this error:
keytool error: java.lang.Exception: Public keys in reply and keystore don't match
Try this:
Replace your files…
I can connect to my broker via:
mosquitto_sub --cert ca.crt --key ca.key --tls-version tlsv1 -t '#' -p 8883
However, my mqtt binding in openhab cannot. I get this error in openhab console:
15:23:48.293 [ERROR] [openhab.io.transport.mqtt.MqttService] - Error starting broker connection
org.eclipse.paho.client.mqttv3.MqttException: Unable to connect to server
        at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:79) [202:org.openhab.io.transport.mqtt:1.12.0]
        at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:650) [202:org.openhab.io.transport.mqtt:1.12.0]
        at java.lang.Thread.run(Thread.java:745) [?:?]
Caused by: java.net.ConnectException: Connection refused
        at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
        at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
        at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
        at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
        at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
        at java.net.Socket.connect(Socket.java:589) ~[?:?]
        at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:70) ~[?:?]
        ... 2 more
my configurations:
/etc/openhab2/services/mqtt.cfg:
mosquitto.url=ssl://localhost:8883
mosquitto.user=mqtt_user
mosquitto.pwd=password
mosquitto.qos=1
mosquitto.retain=true
mosquitto.async=false
mosquitto.clientId=openhab2
/etc/mosquitto/mosquitto.conf
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
Allow_anonymous true
Password_file /etc/mosquitto/pwfile
Listener 8883
cafile /etc/mosquitto/ca_certificates/ca.crt
keyfile /etc/mosquitto/certs/server.key
certfile /etc/mosquitto/certs/server.crt
tls_version tlsv1
/usr/share/openhab2/runtime/bin/setenv:
export JAVA_OPTS="${JAVA_OPTS}
  -Dopenhab.home=${OPENHAB_HOME}
  -Dopenhab.conf=${OPENHAB_CONF}
  -Dopenhab.runtime=${OPENHAB_RUNTIME}
  -Dopenhab.userdata=${OPENHAB_USERDATA}
  -Dopenhab.logdir=${OPENHAB_LOGDIR}
  -Dfelix.cm.dir=${OPENHAB_USERDATA}/config
  -Djetty.host=${HTTP_ADDRESS}
  -Djetty.http.compliance=RFC2616
  -Dorg.ops4j.pax.web.listening.addresses=${HTTP_ADDRESS}
  -Dorg.osgi.service.http.port=${HTTP_PORT}
  -Dorg.osgi.service.http.port.secure=${HTTPS_PORT}"
  -Dcom.ibm.ssl.trustManager=SunX509
  -Dcom.ibm.ssl.keyManager=SunX509
  -Dcom.ibm.ssl.contextProvider=SunJSSE
  -Dcom.ibm.ssl.keyStore=/etc/keystore.jks
  -Dcom.ibm.ssl.keyStorePassword=adminadmin
  -Dcom.ibm.ssl.keyStoreType=JKS
  -Dcom.ibm.ssl.keyStoreProvider=SUN
  -Dcom.ibm.ssl.trustStore=/etc/truststore.jks
  -Dcom.ibm.ssl.trustStorePassword=adminadmin
  -Dcom.ibm.ssl.trustStoreType=JKS
  -Dcom.ibm.ssl.trustStoreProvider=SUN
It is a very long time I have done this
I have since done a full re-install of OH on a new ubuntu OS and the SSL worked out of the box
Which version of openHAB are you running?
Read also the other posts under the original post. Some users had some work arounds and other ideas
I’m using version 2.3.0
why would you bother encrypting the data between 2 local processes ?
This is just a test. latter I’ll go global. Please tell me why I’m getting this error
did you fix your JKS?
In which stage/config file? Please be specific.
i was very specific :slight_smile: (I quoted your previous post where you reported that you were getting an error during the keytool import)… did you fix that step?
Yes. I fixed it. Otherwise, I couldn’t continue this tutorial.
edit.. I can’t see something wrong
First, I did exactly what this said. And then I followed this tutorial.
It would be great, if you helped me fix this issue.
Here is an error to fix: “-keystore.jsk” is not a valid parameter, probably “-keystore keystore.jsk” should be used
