Hi folks,
Probably a noob question. I’ve got a switch bound to an mqtt trigger. If I use the GUI the mqtt binding is triggered and the state is published to the mqtt broker. However if the state of this switch is changed via a rule I’ve got the mqtt binding doesn’t seem to get triggered. The rule I have is watching the Item temperature and turning on or off the heater & cooler switches.
How do I get the mqtt binding triggered when I change the state based on rules?
My Items config looks like this:
Switch Heating_GF_Kitchen "Kitchen heater" <heating> (GF_Kitchen,Heating) { mqtt="> [mosquitto:/myhouse/kitchen/Heating_GF_Kitchen:command:ON:1],>[mosquitto:/myhouse/kitchen/Heating_GF_Kitchen:command:OFF:0]" } Switch Cooler_GF_Kitchen "Kitchen cooler" <heating> (GF_Kitchen,Heating) { mqtt=">[mosquitto:/myhouse/kitchen/Cooler_GF_Kitchen:command:ON:1],>[mosquitto:/myhouse/kitchen/Cooler_GF_Kitchen:command:OFF:0]" }
My rules file looks like this:
`import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
import org.joda.time.*
var int tempHigh = 26
var int tempLow = 25
/* Turn on Kitchen heater when temp is below tempLow */
rule "Control Kitchen heater"
Item Temperature_GF_Kitchen received update
if (Temperature_GF_Kitchen.state < tempLow)
postUpdate(Heating_GF_Kitchen, ON)
else if (Temperature_GF_Kitchen.state >= tempLow)
postUpdate(Heating_GF_Kitchen, OFF)
/* Turn on the cooler if above tempHigh */
rule "Control Kitchen Cooler"
if (Temperature_GF_Kitchen.state > tempHigh)
postUpdate(Cooler_GF_Kitchen, ON)
else if (Temperature_GF_Kitchen.state <= tempHigh)
postUpdate(Cooler_GF_Kitchen, OFF)
end`
Thanks in advance.
Regards
Kheeran
