15:37:01.765 [WARN ] [ore.service.AbstractWatchQueueReader] - Could not process config file '.#mqtt.cfg': java.io.FileNotFoundException: /volume1/@appstore/openHAB2/conf/services/.#mqtt.cfg (No such file or directory)
But this file exists and has permissions 100777, like other cfg files.
What should i do to fix that error?
OK, something is trying to open a file of a different name then. I’m away from the computer right now but maybe someone has an idea where the incorrect name is coming from?
Sorry, I have no clue where the bad filename came from. It’s certainly possible it was a bug fixed in a later build. You might want to first explore your configuration by trying these commands:
I updated to #629, MQTT starts ok, but other strange error appears:
2016-12-03 23:18:11.777 [WARN ] [.core.internal.folder.FolderObserver] - Cannot open file '/volume1/@appstore/openHAB2/conf/rules/.#home.rules' for reading.
java.io.FileNotFoundException: File '/volume1/@appstore/openHAB2/conf/rules/.#home.rules' does not exist
2016-12-03 23:11:31.516 [WARN ] [.core.internal.folder.FolderObserver] - Cannot open file '/volume1/@appstore/openHAB2/conf/items/.#home.items' for reading.
java.io.FileNotFoundException: File '/volume1/@appstore/openHAB2/conf/items/.#home.items' does not exist
After 5min rules started.
All timers are throws erros as rules file starts.
JS, MAP transformations & jdbc persistence starts after 7-9min.
