- Platform information:
- Hardware: Atom64/4GB
- OS: Linux debian/sid
- Java Runtime Environment: Not even sure…
- openHAB version: 2.4.0
I’ve had OpenHAB running for a while, but just noticed that it’s stopped communicating properly with my MQTT server. I’m not aware of any changes since the last time I observed it working, but debugging it has been rather frustrating.
My config is basically:
eve.url=tcp://localhost:1883
eve.user=openhab
eve.pwd=something
eve.retain=true
and a variety of things referencing ‘eve’ which previously worked, and now don’t at all.
I can see my MQTT server receiving a connection from openhab:
1546021690: New client connected from 127.0.0.1 as paho9305337983803391 (c1, k60, u’openhab’).
but it doesn’t talk other than that. I set a LWT and could see it add that once, but nothing else.
An example item that used to work that OpenHAB doesn’t seem to be paying attention to is:
Number B_FamilyRoom_Temperature "Temperature [%.1f °C]" <temperature> (B_FamilyRoom, gTemperature, TimeoutGroup, myOpenHAB) ["CurrentTemperature"] {mqtt="<[eve:sj/basement/plant-temp:state:default]", expire="1h"}
I also noticed in the Paper UI I’m given the option to install the MQTT binding, but pressing the button doesn’t do much.
The only relevant log entries I can find look like this:
2018-12-28 10:53:08.501 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-12-28 10:53:08.516 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'eve'
How can I go about making this work again?
