Do you mean for e.g. a base64 encoded string of binary data? I’m just wondering from a practical level how you would send pure binary data over MQTT.
using the -f
(file) option:
but I don’t think that you can use OH2 MQTT bound Items to do this
I think that here, @vzorglub is right: OH2 MQTTv1 will only publish strings for payloads.
maybe you can do binary with the MQTT Action (doubt it)
This would be a nice test: use an Image item and subscribe to a topic. publish the image using MQTTfx (or mosquitto_pub) and see if OH2 item will get it
We are going way off-topic (again)
Started to experiment with this binding today to migrate all my existing mqtt items and noticed a minor bug: when setting up the broker, the ‘Client ID’ is not set to the value I put in the field (in paperui) and instead overwritten with a random string. Nothing important, so don’t make it a priority Thanks for all your work!
Edit: More pressing issues when trying to create things in paperui. I could create a broker, which successfully connects to mosquitto. But when i try to create a ‘topic’ thing, it seems like it doesn’t use the broker thing. I can choose the broker bridge I created, but when I create a channel on the topic thing it goes offline.
OFFLINE - COMMUNICATION_ERROR java.lang.Exception: No MQTT client
The channel id gets set to mqtt:topic:<thing id>:<channel id>
but i believe it should be mqtt:<broker>:topic:<thing id>:<channel id>
I will try a manual configuration in .things
-files and see if it works, in which case there’s an issue either in paperui or how the binding handles the thins created there.
Edit 2: Seems that stopping and restarting the openhab 1.x mqtt bundles resolved it. Perhaps there is some conflict between them?
Are you using OH snapshots? This sounds like a problem fixed some weeks ago.
I’m using M6, but as I wrote in my second edit, a restart of all mqtt-bundles (both 1.x and 2.x versions) solved it
Newbie alert.
Can anyone help me with linking a master(docker in a VM) and slave(openhabianpi with z wave controller) openhab configuration with mqtt eventbus/or the newer way of doing it with binding 2.4?
Hi, don’t even think about using MQTTv2 to setup such “link”
We haven’t tested this integration so you will enter in deep waters almost alone
(unless of course you want to break new ground and be a pioneer… in this case go ahead )
It’s better to leave this thread alone for the developments of MQTTv2 and open up a new one asking your stuff
Noted with thanks. I will stick with the 1.13 binding for now then.
I am using mqtt 2.4 binding to extract values from a topic using jsonpath. Every time a value is extracted I got a warning in OH log. This happens for all channels that are linked to an item. The extract works well. Thanks for any suggestions.
Log message:
2018-11-26 09:02:36.944 [WARN ] [ofiles.JSonPathTransformationProfile] - Please specify a function and a source format for this Profile in the 'function' and 'sourceFormat' parameters. Returning the original state now.
MQTT message:
Client mosqsub/20978-openHABia received PUBLISH (d0, q0, r0, m0, 'tasmota/sonoff_heater/tele/SENSOR', ... (303 bytes))
{"Time":"2018-11-26T09:04:35","DS18B20-1":{"Id":"000006B54467","Temperature":49.6},"DS18B20-2":{"Id":"000006B56D00","Temperature":37.1},"DS18B20-3":{"Id":"000006B66271","Temperature":40.9},"DS18B20-4":{"Id":"000006B7001D","Temperature":43.3},"AM2301":{"Temperature":23.1,"Humidity":47.0},"TempUnit":"C"}
JSONPATH example:
JSONPATH:$.DS18B20-4.Temperature
For some reason having restarted my OH2, my Generic MQTT Things will not go online anymore.
The reason is fairly nondescript as to why:
UNINITIALIZED - HANDLER_CONFIGURATION_PENDING
These were complete configured through Paper UI and working until I restarted so it seems like a bug somewhere in the handler start up. If I have time towards the end of the week I’ll try and debug it.
Your oh got updated. I needed to change channel type names, so all things created before X will go offline if such an old channel is part of it.
I have already changed the offline message in an update to shed some light on this.
Not sure that is why. I am on latest snapshot and these are newly created Things (yesterday) - my OH2 hasn’t been updated since.
Check that switches have a command entry, that was my problem
Exactly my problem too. Adding in a dummy topic brought my Thing back online.
Edit: It looks like this line would need changing so that commandTopic
is not required for the Thing to come online.
The fact that you can create a Thing that will go online the first time without a required parameter but not after a restart also seems like a bug but I’m not sure if this is in the binding (not so important if it will be changed) or the framework (probably more important).
Edit 2: An alternative approach may be to create a new Binary Sensor thing type which only has a state topic rather than a command topic.
I’m having problems with textual configuration.
Using the latest snapshot #1445 and have my broker setup texually just fine. But there is something strange when I try to set up a generic thing as per https://github.com/eclipse/smarthome/blob/master/extensions/binding/org.eclipse.smarthome.binding.mqtt.generic/README.md. The thing does not get created. If I edit out the broker from the thing ie: mqtt:topic:mything, the thing gets created and I can add the broker through the bridge selection in paperui although it throws a : ERROR: 409 conflict.
Those problems are all fixed in snapshots newer than today
Read-only switches are now possible.
I’m not using the textual configuration, so I do not test any of my bindings with textual configurations. I assume that if Paper UI works, textual should work as well. So my advice is: Have you tried to use Paper UI for configuration as well?
Cheers, David
Hi David,
I have a problem with that code :
Bridge mqtt:broker:mynewsnips "MQTT Broker 2" [ host="192.168.1.2", username="user", password="xxxx" ]
Thing topic mything "Generic MQTT Thing 2"
Channels:
Type string : testmqttrois "mqtttestrois" [ stateTopic="hermes/hotword/default/detected", stateCommand="", formatBeforePublish="" ]
The broker seems ok, the generic MQTT seems ok.
When i go in paperui, i can see the channel. But when i edit it, state topic is empty and formatBeforePublish is always with %s. It’s like my parameter above was not read.
I tried with mqttstate
and mqttcommand
too, but the result is the same.
When all is configured from paperui, it’s OK.
Have you an idea ?
Thank you
Ced
**edit 2 : **
It’s Ok now. I did apt-get dist-upgrade 4 hours ago and i did it now. There was an update during this time.
Thank you !
Hi @David_Graeff is there a solution implemented yet so that a channel can receive an INCREASE or DECREASE payload?
A dimmer/percentage channel can process increase/decrease commands. What exactly do you mean?
