MQTT binding with rpi
i really appreciate some help about mqtt binding.
i’m trying communicate with my rpi to open a selected gpio.
To do so i use the mqtt protocol and it’s working fine (i installed mosquitto and try some terminal commands).
pi@pi02 ~ $ mosquitto_sub -t home/in/5
0
1
0
pi@tp01:~ $ mosquitto_pub -h 192.168.1.53 -t home/in/5 -m "0"
pi@tp01:~ $ mosquitto_pub -h 192.168.1.53 -t home/in/5 -m "1"
pi@tp01:~ $
Everything is working, i can hear the relay turning on/off (for an easy task i’m trying to make a switch on openhab and see if it’s working).
Items:
Switch mySwitch {mqtt=">[mymosquitto:home/in/5:command:ON:1],>[mymosquitto:home/in/5:command:OFF:0]"}
Sitemap:
sitemap default label=“Main Menu”
Frame label=“MQTT Test” {
Switch item=mySwitch
Openhab.cfg
MQTT Transport
mqtt:mymosquitto.url=tcp://192.168.1.53:1883
mqtt:mymosquitto.retain=true
mqtt:mymosquitto.clientId=MyMQTT
mqtt-gpio-monitor.ini
[global]
MODULE = gpio
DEBUG = True
MQTT_HOST = 127.0.0.1
MQTT_PORT = 1883
MQTT_USERNAME = test1
MQTT_PASSWORD = test
MQTT_CLIENT_ID = mqtt-gpio-monitor
MQTT_QOS = 0
MQTT_RETAIN = True
MQTT_CLEAN_SESSION = True
MQTT_TOPIC = home
MQTT_LWT = /clients/mqtt-gpio-monitor
MONITOR_PINS = 3, 5, 11, 13
MONITOR_POLL = 0.1
MONITOR_REFRESH = /mqtt-gpio-monitor/refresh
Log file:
2016-02-08 09:57:04.206 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.7.0).
2016-02-08 09:57:24.192 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-02-08 09:57:29.967 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.items’
2016-02-08 09:57:30.131 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-02-08 09:57:30.231 [INFO ] [.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2016-02-08 09:57:30.265 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mymosquitto’
2016-02-08 09:57:56.693 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.sitemap’
2016-02-08 09:58:04.591 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-02-08 09:58:10.321 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /openhab.app
2016-02-08 10:11:33.567 [INFO ] [penhab.io.rest.RESTApplication] - Stopped REST API
2016-02-08 10:11:37.667 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Stopped Classic UI
No message sent to rpi and nothing on the topic (as you can see i’m sub to home/in/5)
Any ideas?
