I’m coming from OH2.5 where I used the 1.x MQTT binding with an external Mosquitto broker.
After a lot of research I found that you need to create a bridge Broker and a Generic MQTT thing and then add channels for each topic. A bit complex to setup, but it works.
Now somehow I also have a “MQTT system broker connection” at the Settings page.
What does this MQTT system broker do, and do I need to configure it?
It keeps complaining about the host/IP not being setup, but looks like I don’t need this? How can I can rid of this entry? 2020-12-22 12:04:14.458 [WARN ] [.MqttBrokerConnectionServiceInstance] - MqttBroker connection configuration faulty: host : You need to provide a hostname/IP!
I think that’s a way to set up a “default” MQTT broker connection. You don’t need to do anything there if you create Broker Things. But I’m not really sure. I haven’t messed with it.
Have you edited or even just clicked “save” from that menu? You do need the host/IP to have a valid MQTT connection to a broker. If you’ve clicked save, perhaps it generated an empty config and that’s what it is complaining about. You can see if you have a $OH_USERDATA/config/org/openhab/mqtt.config file. If so try stopping OH and deleting it.
Thanks, it lead me to the solution.
In my case it was the file mqttbroker.config in that $OH_USERDATA/config/org/openhab/ dir (created over a year ago) that was causing the error to show. Deleted it and all is fine now.
@Qwerty_Zet I tried your solution too, in my case it didn’t solve it. Toch bedankt!
Although I have just installed it, I did not have any settings. I did what you said above. not resolved. Why don’t the friends who write OH3 see these problems and offer suggestions for solutions?
