Gday,
Well I have managed to set up a Mysensors MQTT gateway which I was quite pleased with and have a simple PIR sensor connected too it and it works!
When I look to openHAB I noticed that every 2 minutes (almost exactly) the broker connection was lost.
Is there are setting or reason this would occur? (MQTTlens seems to stay connected ok)
2016-02-06 **23:31:36.661** [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
org.eclipse.paho.client.mqttv3.MqttException: Unexpected error
at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:115) ~[na:na]
at java.lang.Thread.run(Unknown Source) [na:1.8.0_71]
2016-02-06 23:31:41.403 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mysensors' was lost: Unexpected error : ReasonCode 6 : Cause : Unknown
2016-02-06 23:31:41.403 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mysensors'
2016-02-06 23:31:51.419 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mysensors'
2016-02-06 **23:33:36.663** [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
2016-02-06 23:33:42.785 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mysensors' was lost: Unexpected error : ReasonCode 6 : Cause : Unknown
2016-02-06 23:33:42.786 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mysensors'
2016-02-06 23:33:52.787 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mysensors'
2016-02-06 **23:35:36.661** [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to broker was lost
2016-02-06 23:35:40.080 [ERROR] [o.i.t.m.i.MqttBrokerConnection] - MQTT connection to 'mysensors' was lost: Unexpected error : ReasonCode 6 : Cause : Unknown
2016-02-06 23:35:40.080 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting connection helper to periodically try restore connection to broker 'mysensors'
2016-02-06 23:35:50.082 [INFO ] [o.i.t.m.i.MqttBrokerConnection] - Starting MQTT broker connection 'mysensors'
I cant seem to get the item to display its state on the sitemap,
I have the item set up as a switch with a simple map and can see its state coming in on the logs,
Switch mysPIR1 "mysPIR" {mqtt="<[mysensors:MyMQTT/20/1/V_TRIPPED:state:MAP(1on0off.map)]"}
2016-02-06 23:45:03.535 [INFO ] [runtime.busevents ] - mysPIR1 state updated to OFF
2016-02-06 23:45:09.666 [INFO ] [runtime.busevents ] - mysPIR1 state updated to ON
On the sitemap I have this, but it just doesn’t show the switch changing state.
Text item=mysPIR label="myPIR [MAP(1on0off.map):%s]" icon="info"
Could someone point me in the right direction with this?
Regards,
George
