2019-04-09 07:41:58.245 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to ‘127.0.0.1’. Next attempt in 10000ms
2019-04-09 07:41:58.248 [WARN ] [r.internal.EmbeddedBrokerServiceImpl] - Embedded broker offline - Reason unknown
2019-04-09 07:41:58.261 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘127.0.0.1’ with clientid embedded-mqtt-broker and file store ‘/var/lib/openhab2/mqtt/127.0.0.1’
2019-04-09 07:41:58.319 [WARN ] [r.internal.EmbeddedBrokerServiceImpl] - Embedded broker offline
org.eclipse.paho.client.mqttv3.MqttException: MqttException
at org.eclipse.paho.client.mqttv3.internal.ExceptionHelper.createMqttException(ExceptionHelper.java:38) ~[232:org.eclipse.paho.client.mqttv3:1.2.0]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:715) [232:org.eclipse.paho.client.mqttv3:1.2.0]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
at sun.security.ssl.InputRecord.readFully(InputRecord.java:465) ~[?:?]
at sun.security.ssl.InputRecord.read(InputRecord.java:503) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:975) ~[?:?]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.SSLNetworkModule.start(SSLNetworkModule.java:108) ~[?:?]
at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:701) ~[?:?]
… 7 more
