i installed Mosquitto with openhabian, installed MQTT Binding and added the MQTT Broker in the GUI.
But the Broker won’t start/connect:
2021-08-19 22:51:17.530 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '192.168.1.100' with clientid openHAB
2021-08-19 22:51:17.527 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:riot' changed from OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED. to OFFLINE
2021-08-19 22:51:17.553 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'mqtt:broker:riot' changed from OFFLINE to OFFLINE (COMMUNICATION_ERROR): CONNECT failed as CONNACK contained an Error Code: NOT_AUTHORIZED.
What did i miss ?
Thank you!
