Hi there,
first of all: thank you very much for your efforts in supporting open-source-software.
I’m on my first bigger diy project and ran into the following problem: I try to make a smart ventilation out of some pc-fans. I supply them by a zigbee-led-rgb-controller, which is working fine. I can set the fan-speed by adjusting “brightness” in zigbee2mqtt-frontend and “select” one or the other fans as green (0,255,0) or blue (0,0,255) colour. So far, so good.
Now i want to implement this in openhab3. Later, the fans shall operate automated. For now, i even fail to control it via openhab at all. I’ve tried to send a mosquitto_pub message which didn’t work out:
mosquitto_pub -u openhabian --pw *** -t "Zigbee2mqtt/Testlüftung/set" -m {"brightness":250}
I created a channel in the mqtt-broker, with zigbee2mqtt/Testlüftung as topic - but this too doesn’t trigger the fan.
I tried some tutorials, but it seems to me that, at some point, some information for a noob like me is missing. And it didn’t work out in the end too… Please help. What kind of information do you need?
Thanks in advance!
- Platform information:
- Hardware: Raspberry Pi 3 B
- OS: openHABian
- Java Runtime Environment: ?
- openHAB version: 3
- Issue of the topic: I set up a MQTT-Broker and try to communicate with a MQTT-Thing
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
