MQTT Chart Persistence no results are saved
I am using ESP8266 to read Temperature and Humidity from a DHT22 over MQTT and what to show the Chart but somehow it does not save the state of the temp, hum.
My mqtt.item:
Group WeatherIO
Number Indoor_Temp "WZ Temperatur [%.1f]" <temperature> (WeatherIO) ["CurrentTemperature"] {mqtt="<[mosquitto:home/temperature:state:default]"}
Number Indoor_Hum "WZ Feuchtigkeit [%.1f]" <humidity> (WeatherIO) ["CurrentHumidity"] {mqtt="<[mosquitto:home/humidity:state:default]"}
My mqtt.sitemap:
sitemap mqtt label="Home" {
        Frame label="Chart" {
                Text item=Indoor_Temp {
                        Chart item=Indoor_Temp period=h refresh=10
                        Chart item=Indoor_Temp period=d refresh=10
                Text item=Indoor_Hum {
                        Chart item=Indoor_Hum period=h refresh=10
                        Chart item=Indoor_Hum period=d refresh=10
My mqtt.persist
Strategies {
   everyMinute  : "0 * * * * ?"
   everyHour    : "0 0 * * * ?"
   everyDay     : "0 0 0 * * ?"
   default = everyChange
Items {
   * : strategy = everyChange, everyHour
The Log:
16:53:11.905 [ERROR] [.voice.mactts.internal.MacTTSService] - Error while executing the 'say -v ?' command: Cannot run program "say": error=2, No such file or directory
16:53:20.203 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'yahooweather.items'
16:53:37.450 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'standard.items'
16:53:37.539 [WARN ] [core.internal.items.ItemRegistryImpl] - Could not add item: The specified name of the item 'null' is not valid!
java.lang.IllegalArgumentException: The specified name of the item 'null' is not valid!
	at org.eclipse.smarthome.core.items.ItemUtil.assertValidItemName(ItemUtil.java:75)[98:org.eclipse.smarthome.core:0.9.0.b4]
	at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.initializeItem(ItemRegistryImpl.java:255)[98:org.eclipse.smarthome.core:0.9.0.b4]
	at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.onAddElement(ItemRegistryImpl.java:307)[98:org.eclipse.smarthome.core:0.9.0.b4]
	at org.eclipse.smarthome.core.internal.items.ItemRegistryImpl.allItemsChanged(ItemRegistryImpl.java:102)[98:org.eclipse.smarthome.core:0.9.0.b4]
	at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:341)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:207)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
	at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:99)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:272)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.notifyUpdateToModelRepo(FolderObserver.java:199)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
	at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.updated(FolderObserver.java:180)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
	at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12]
	at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12]
	at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12]
	at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1461)[3:org.apache.felix.configadmin:1.8.12]
	at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1417)[3:org.apache.felix.configadmin:1.8.12]
	at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12]
	at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12]
	at java.lang.Thread.run(Thread.java:745)[:1.8.0_65]
16:53:37.609 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rdd4j.persist'
16:53:40.617 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mqtt.rules'
16:53:42.298 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'standard.sitemap'
16:53:58.072 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Test_HumidityRRD4J-yahooweather:weather:wien:humidity' has been added.
16:53:58.350 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'yahooweather.things'
16:54:00.154 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Test_PressureRRD4J-yahooweather:weather:wien:pressure' has been added.
16:54:00.172 [INFO ] [home.event.ItemChannelLinkAddedEvent] - Link 'Test_TemperatureRRD4J-yahooweather:weather:wien:temperature' has been added.
16:54:01.684 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
16:54:02.081 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
16:54:02.165 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
16:54:02.254 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
16:54:03.654 [INFO ] [ulation.internal.HueEmulationServlet] - Started Hue Emulation service at /api
16:54:18.356 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
16:54:18.817 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
16:54:18.366 [INFO ] [b.core.service.AbstractActiveService] - HTTP Refresh Service has been started
16:54:24.471 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'mosquitto'
16:54:24.692 [ERROR] [ab.binding.http.internal.HttpBinding] - given config key 'format' does not follow the expected pattern '<id>.<url|updateInterval>'
16:54:24.730 [INFO ] [marthome.event.ItemStateChangedEvent] - Indoor_Temp changed from NULL to 22.20
16:54:24.734 [INFO ] [ome.event.GroupItemStateChangedEvent] - WeatherIO changed from NULL to UNDEF through Indoor_Temp
16:54:24.771 [INFO ] [marthome.event.ItemStateChangedEvent] - Indoor_Hum changed from NULL to 50.30
16:54:24.851 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
16:54:25.032 [INFO ] [smarthome.event.ThingAddedEvent     ] - Thing 'yahooweather:weather:wien' has been added.
16:54:25.086 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'yahooweather:weather:wien' changed from UNINITIALIZED to INITIALIZING
16:54:25.098 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'yahooweather:weather:wien' changed from INITIALIZING to ONLINE
16:54:26.374 [INFO ] [ome.event.GroupItemStateChangedEvent] - gTestWeather changed from NULL to UNDEF through Test_TemperatureRRD4J
16:54:28.057 [INFO ] [marthome.event.ItemStateChangedEvent] - Test_TemperatureRRD4J changed from NULL to 11
16:54:28.060 [INFO ] [marthome.event.ItemStateChangedEvent] - Test_HumidityRRD4J changed from NULL to 29
16:54:28.066 [INFO ] [marthome.event.ItemStateChangedEvent] - Test_PressureRRD4J changed from NULL to 990.00
16:54:33.563 [INFO ] [marthome.event.ItemStateChangedEvent] - Indoor_Hum changed from 50.30 to 50.50
16:55:05.636 [INFO ] [marthome.event.ItemStateChangedEvent] - Indoor_Hum changed from 50.50 to 50.30
16:56:32.801 [INFO ] [marthome.event.ItemStateChangedEvent] - Indoor_Hum changed from 50.30 to 50.50
Installed are the Addons MQTT Persistence and RDDJ4 Persistence. Any ideas?
