I am running version 3.4.0.M4 in a docker container.
MQTT binding is installed
and this is my mqtt.things file in config/things folder
Bridge mqtt:broker:mymosquitto "mqtt Broker" [host="192.168.100.11", secure=false, clientID="openHAB", port=1883 ]
Thing mqtt:topic:zuhause "mqtt Zuhause"
Channels:
Type number : heizstromimpuls "Impuls" [stateTopic="SCHALTSCHRANK/Heizstrom/Count"]
Type number : heizstromzeit "Impulsdauer" [stateTopic="SCHALTSCHRANK/Heizstrom/Time"]
Type number : heizstromgesamt "Gesamtverbrauch" [stateTopic="SCHALTSCHRANK/Heizstrom/Total"]
Type number : dose_wama_power "WaMa Leistung" [stateTopic="Dose-WaMa/power"]
Type number : dose_wama_voltage "WaMa Spannung" [stateTopic="Dose-WaMa/voltage"]
Type number : dose_wama_energy "WaMa Verbrauch" [stateTopic="Dose-WaMa/energy"]
Type number : dose_wama_current "WaMa StromstÀrke" [stateTopic="Dose-WaMa/current"]
Type number : dose_trockner_power "Trockner Leistung" [stateTopic="Dose-Trockner/power"]
Type number : dose_trockner_voltage "Trockner Spannung" [stateTopic="Dose-Trockner/voltage"]
Type number : dose_trockner_energy "Trockner Verbrauch" [stateTopic="Dose-Trockner/energy"]
Type number : dose_trockner_current "Trockner StromstÀrke" [stateTopic="Dose-Trockner/current"]
Type number : dose_stereo_max_power "Stereoanlage-Max Leistung" [stateTopic="Dose-Stereo-Max/power"]
Type number : dose_stereo_max_voltage "Stereoanlage-Max Spannung" [stateTopic="Dose-Stereo-Max/voltage"]
Type number : dose_stereo_max_energy "Stereoanlage-Max Verbrauch" [stateTopic="Dose-Stereo-Max/energy"]
Type number : dose_stereo_max_current "Stereoanlage-Max StromstÀrke" [stateTopic="Dose-Stereo-Max/current"]
Type number : dose_stereo_emmi_power "Stereoanlage-Emmi Leistung" [stateTopic="Dose-Stereo-Emmi/power"]
Type number : dose_stereo_emmi_voltage "Stereoanlage-Emmi Spannung" [stateTopic="Dose-Stereo-Emmi/voltage"]
Type number : dose_stereo_emmi_energy "Stereoanlage-Emmi Verbrauch" [stateTopic="Dose-Stereo-Emmi/energy"]
Type number : dose_stereo_emmi_current "Stereoanlage-Emmi StromstÀrke" [stateTopic="Dose-Stereo-Emmi/current"]
Type number : dose_fernseher_power "Multimedia Leistung" [stateTopic="Dose-Fernseher/power"]
Type number : dose_fernseher_voltage "Multimedia Spannung" [stateTopic="Dose-Fernseher/voltage"]
Type number : dose_fernseher_energy "Multimedia Verbrauch" [stateTopic="Dose-Fernseher/energy"]
Type number : dose_fernseher_current "Multimedia StromstÀrke" [stateTopic="Dose-Fernseher/current"]
Type number : dose_drucker_power "Drucker Leistung" [stateTopic="Dose-Drucker/power"]
Type number : dose_drucker_voltage "Drucker Spannung" [stateTopic="Dose-Drucker/voltage"]
Type number : dose_drucker_energy "Drucker Verbrauch" [stateTopic="Dose-Drucker/energy"]
Type number : dose_drucker_current "Drucker StromstÀrke" [stateTopic="Dose-Drucker/current"]
Type number : dose_gefrierschrank_power "Gefrierschrank Leistung" [stateTopic="Dose-Gefrierschrank/power"]
Type number : dose_gefrierschrank_voltage "Gefrierschrank Spannung" [stateTopic="Dose-Gefrierschrank/voltage"]
Type number : dose_gefrierschrank_energy "Gefrierschrank Verbrauch" [stateTopic="Dose-Gefrierschrank/energy"]
Type number : dose_gefrierschrank_current "Gefrierschrank StromstÀrke" [stateTopic="Dose-Gefrierschrank/current"]
Type number : dose_bueroschreibtisch_power "BueroSchreibtisch Leistung" [stateTopic="Dose-BueroSchreibtisch/power"]
Type number : dose_bueroschreibtisch_voltage "BueroSchreibtisch Spannung" [stateTopic="Dose-BueroSchreibtisch/voltage"]
Type number : dose_bueroschreibtisch_energy "BueroSchreibtisch Verbrauch" [stateTopic="Dose-BueroSchreibtisch/energy"]
Type number : dose_bueroschreibtisch_current "BueroSchreibtisch StromstÀrke" [stateTopic="Dose-BueroSchreibtisch/current"]
Type number : dose_lampe_o_power "Lampe O Leistung" [stateTopic="Dose-WZ-LampeO/power"]
Type number : dose_lampe_nw_power "Lampe NW Leistung" [stateTopic="Dose-WZ-LampeNW/power"]
Type number : dose_lampe_sw_power "Lampe SW Leistung" [stateTopic="Dose-WZ-LampeSW/power"]
Type number : dose_lampe_no_power "Lampe NO Leistung" [stateTopic="Dose-WZ-LampeNO/power"]
Type number : dose_lampe_so_power "Lampe SO Leistung" [stateTopic="Dose-WZ-LampeSO/power"]
Type number : dose_staubfilter_power "Staubfilter Leistung" [stateTopic="Dose-Staubfilter/power"]
Type number : dose_staubfilter_voltage "Staubfilter Spannung" [stateTopic="Dose-Staubfilter/voltage"]
Type number : dose_staubfilter_energy "Staubfilter Verbrauch" [stateTopic="Dose-Staubfilter/energy"]
Type number : dose_staubfilter_current "Staubfilter StromstÀrke" [stateTopic="Dose-Staubfilter/current"]
Type number : licht_schuppen_power "Licht Schuppen Leistung" [stateTopic="LICHT-SCHUPPEN/power"]
Type number : licht_schuppen_energy "Licht Schuppen Verbrauch" [stateTopic="LICHT-SCHUPPEN/energy"]
Type switch : dose_drucker_switch "Steckdose Drucker" [stateTopic="Dose-Drucker/relay/0", commandTopic="Dose-Drucker/relay/0/set", on="1",off="0" ]
Type switch : dose_wama_switch "Steckdose Waschmaschine" [commandTopic="Dose-WaMa/relay/0/set", on="1", off="0", stateTopic="Dose-WaMa/relay/0"]
Type switch : dose_trockner_switch "Steckdose Trockner" [commandTopic="Dose-Trockner/relay/0/set", on="1", off="0", stateTopic="Dose-Trockner/relay/0"]
Type switch : dose_fernseher "Multimedia" [commandTopic="Dose-Fernseher/relay/0/set", on="1", off="0", stateTopic="Dose-Fernseher/relay/0"]
Type switch : dose_stereo_emmi "Steckdose Stereoanlage Emmi" [commandTopic="Dose-Stereo-Emmi/relay/0/set",on="1", off="0", stateTopic="Dose-Stereo-Emmi/relay/0"]
Type switch : dose_stereo_max "Steckdose Stereoanlage Max" [commandTopic="Dose-Stereo-Max/relay/0/set", on="1", off="0", stateTopic="Dose-Stereo-Max/relay/0"]
Type switch : dose_lampe_nw "Lampe NW" [commandTopic="Dose-WZ-LampeNW/relay/0/set", on="1", off="0", stateTopic="Dose-WZ-LampeNW/relay/0"]
Type switch : dose_lampe_sw "Lampe SW" [commandTopic="Dose-WZ-LampeSW/relay/0/set", on="1", off="0", stateTopic="Dose-WZ-LampeSW/relay/0"]
Type switch : dose_lampe_no "Lampe NO" [commandTopic="Dose-WZ-LampeNO/relay/0/set", on="1", off="0", stateTopic="Dose-WZ-LampeNO/relay/0"]
Type switch : dose_lampe_o "Lampe O" [commandTopic="Dose-WZ-LampeO/relay/0/set", on="1", off="0", stateTopic="Dose-WZ-LampeO/relay/0"]
Type switch : dose_lampe_so "Lampe SO" [commandTopic="Dose-WZ-LampeSO/relay/0/set", on="1", off="0", stateTopic="Dose-WZ-LampeSO/relay/0"]
Type switch : dose_staubfilter "Steckdose Staubfilter" [commandTopic="Dose-Staubfilter/relay/0/set", on="1", off="0", stateTopic="Dose-Staubfilter/relay/0"]
Type switch : dose_gefrierschank "Steckdose Gefrierschrank" [commandTopic="Dose-Gefrierschrank/relay/0/set", on="1", off="0", stateTopic="Dose-Gefrierschrank/relay/0"]
Type switch : dose_bueroschreibtisch "Steckdose Bueroschreibtisch" [commandTopic="Dose-Bueroschreibtisch/relay/0/set", on="1", off="0", stateTopic="Dose-Bueroschreibtisch/relay/0"]
Type switch : aussen_licht_s "AuĂenlampe S" [commandTopic="LICHT-AUSSEN-S/relay/0/set", on="1", off="0", stateTopic="LICHT-AUSSEN-S/relay/0"]
Type switch : aussen_licht_o "AuĂenlampe O" [commandTopic="LICHT-AUSSEN-O/relay/0/set", on="1", off="0", stateTopic="LICHT-AUSSEN-O/relay/0"]
Type switch : licht_schuppen "Licht Schuppen" [commandTopic="LICHT-SCHUPPEN/relay/0/set", on="1", off="0", stateTopic="LICHT-SCHUPPEN/relay/0"]
Type number : garagentoroben "Garagentor offen" [stateTopic="GARAGE/O1D1G5TorEndlageOben/State"]
Type number : garagentorunten "Garagentor zu" [stateTopic="GARAGE/O2D2G4TorEndlageUnten/State"]
Type switch : garagencheck "Garagenposition nach Paketbote" [stateTopic="RPi_Klingel/garagencheck"]
Type string : rpi_status_uhrzeit "Datum" [stateTopic="RPi_Klingel/time"]
Type number : rpi_status_temperatur "CPU Temperatur" [stateTopic="RPi_Klingel/temp"]
Type number : rpi_status_cpuprozent "CPU Auslastung" [stateTopic="RPi_Klingel/cpu"]
Type number : rpi_status_discuse "Klingelstatus" [stateTopic="RPi_Klingel/diskusage"]
Type switch : rpi_status_kamera "Kamerastatus" [stateTopic="RPi_Klingel/video"]
Type string : klingel_status_input "Klingelstatus" [stateTopic="RPi_Klingel/status"]
Type number : temperatureaussenhinten "Temperatur AuĂenH" [stateTopic="TEMP-AUSSEN/BME680/Temperature"]
Type number : temperatureaussenvorne "Temperatur AuĂenV" [stateTopic="TEMP-AUSSEN/DS18B20/Temperature"]
Type number : humidityaussen "Luftfeuchtigkeit AuĂen" [stateTopic="TEMP-AUSSEN/BME680/Humidity"]
Type number : pressureaussen "Luftdruck AuĂen" [stateTopic="TEMP-AUSSEN/BME680/Pressure"]
Type number : voltageaussen "Spannung Akku" [stateTopic="TEMP-AUSSEN/100k/Spannung"]
Type number : helligkeitaussen "Helligkeit AuĂen" [stateTopic="TEMP-AUSSEN/LICHTSENSOR/Lux"]
Type number : luftqualitaetaussen "LuftqualitĂ€t AuĂen" [stateTopic="TEMP-AUSSEN/BME680/Gas"]
log shows only this entry:
022-11-22 21:38:05.988 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model âmqtt.thingsâ
no further message
I am followed this tutorial:
I tried then to install a mqtt broker bridge in GUI
then added a channel
then added to this channel a number type
between each step I restarted the container to look if the file is recognized anyway.
but the file seems to be not took into account
The channel with the number type was working. But as you may see I would have to do a lot of clicking work to get all mqtt things in âŠ
