I using the stable release OH 2.4.0-1 together with the zingbee2MQTT from Koenkk (https://www.zigbee2mqtt.io/). I followed the instruction on the web page, it is running succecfully.
I have three Zigbee devices, 2 Lamps (IKEA Trådfri LED transformators) and 1 Xiaomi Smart Door Windows Sensor.
All Devices are running well. So for mee is the communication way from zigbee and MQTT to OH running.
Here my example for items:
Dimmer KuecheInsel "Insel" (gLicht) {channel="mqtt:topic:mosquitto:kuechelichtinsel:KuecheInsel"}
Number KuecheInselRSSI "Rssi" {channel="mqtt:topic:mosquitto:kuechelichtinsel:KuecheInselRSSI"}
String KuecheInselSate "Status" {channel="mqtt:topic:mosquitto:kuechelichtinsel:KuecheInselSate"}
Number KuecheArbeitsplatteRSSI "Rssi" {channel="mqtt:topic:mosquitto:kuechelichtarbeitsplatte:KuecheArbeitsplatteRSSI"}
String KuecheArbeitsplatteSate "Status" {channel="mqtt:topic:mosquitto:kuechelichtarbeitsplatte:KuecheArbeitsplatteSate"}
Dimmer KuecheArbeitsplatte "Arbeitsplatte" (gLicht) {channel="mqtt:topic:mosquitto:kuechelichtarbeitsplatte:KuecheArbeitsplatte"}
Here the a part of my MQTT.things:
Thing topic kuechelichtinsel "Küche Licht Insel" {
Channels:
Type number : KuecheInselRSSI "RSSI" [stateTopic="zigbee2mqtt/0x90fd9ffffe75105c", transformationPattern="JSONPATH:$.linkquality"]
Type string : KuecheInselSate "Status" [stateTopic="zigbee2mqtt/0x90fd9ffffe75105c", transformationPattern="JSONPATH:$.state"]
Type dimmer : KuecheInsel "Insel" [stateTopic="zigbee2mqtt/0x90fd9ffffe75105c", commandTopic="zigbee2mqtt/0x90fd9ffffe75105c/set", formatBeforePublish="{ \"brightness\": %s }" ]
OK Type dimmer : KuecheInsel3 "Test Lamp" [stateTopic="zigbee2mqtt/0x90fd9ffffe75105c", commandTopic="zigbee2mqtt/0x90fd9ffffe75105c/set", min=1, max=254, step=1, transformationPattern="JSONPATH:$.brightness", formatBeforePublish="{ \"brightness\": %s }" ]
NG Type dimmer : KuecheInsel3 "Insel" [stateTopic="zigbee2mqtt/0x90fd9ffffe75105c", commandTopic="zigbee2mqtt/0x90fd9ffffe75105c/set", min=1, max=254, step=1, transformationPattern="JSONPATH:$.brightness", formatBeforePublish="{ \"brightness\": %s }" ]
NG Type dimmer : KuecheInsel3 "Led strip dimmer" [stateTopic="zigbee2mqtt/0x90fd9ffffe75105c", commandTopic="zigbee2mqtt/0x90fd9ffffe75105c", min=0, max=100, step=1]
Thing topic kuechelichtarbeitsplatte "Küche Licht Arbeitsplatte" {
Channels:
Type number : KuecheArbeitsplatteRSSI "RSSI" [stateTopic="zigbee2mqtt/0x000b57fffea3c341", transformationPattern="JSONPATH:$.linkquality"]
Type string : KuecheArbeitsplatteSate "Status" [stateTopic="zigbee2mqtt/0x000b57fffea3c341", transformationPattern="JSONPATH:$.state"]
Type dimmer : KuecheArbeitsplatte "Arbeitsplatte" [stateTopic="zigbee2mqtt/0x000b57fffea3c341", commandTopic="zigbee2mqtt/0x000b57fffea3c341/set", formatBeforePublish="{ \"brightness\": %s }" ]
My Problem is, that I get the following warning on every change of light brightness:
2019-10-20 01:43:05.966 [WARN ] [eneric.internal.generic.ChannelState] - Incoming payload ‘{“state”:“ON”,“linkquality”:0,“brightness”:72}’ not supported by type ‘PercentageValue’
and sometimes the following Error message:
2019-10-20 01:42:30.993 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.eclipse.smarthome.binding.mqtt.generic.internal.handler.GenericThingHandler@f0c2b3’: null
java.lang.NumberFormatException: null
at java.math.BigDecimal.<init>(BigDecimal.java:494) ~[?:?]
at java.math.BigDecimal.<init>(BigDecimal.java:383) ~[?:?]
at java.math.BigDecimal.<init>(BigDecimal.java:806) ~[?:?]
at org.eclipse.smarthome.core.library.types.DecimalType.<init>(DecimalType.java:57) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.library.types.PercentType.<init>(PercentType.java:47) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.library.types.PercentType.valueOf(PercentType.java:63) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.binding.mqtt.generic.internal.values.PercentageValue.update(PercentageValue.java:87) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.generic.ChannelState.publishValue(ChannelState.java:302) ~[?:?]
at org.eclipse.smarthome.binding.mqtt.generic.internal.handler.AbstractMQTTThingHandler.handleCommand(AbstractMQTTThingHandler.java:119) ~[?:?]
at sun.reflect.GeneratedMethodAccessor82.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy158.handleCommand(Unknown Source) [232:org.eclipse.smarthome.binding.mqtt.generic:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor81.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
The next thing is, that the lamps goes not to brightness level of 254 only 100.
I read several topics here but I did not understand the releation between the several MQTT version etc.
I found no topic which can solve my problem.
It this currently a bug in the MQTT part or not? And if not how can I solve this.
Thank you very much
Holgus
