I was missing the possibility to use an old style twist type dimmer with my home automation so i tried to use a nodeMCU board with MQTT to send dimmer values to openhab using a KY-040 rotary encoder. I can use the same encoder to dim several lamps by pushing the button to change modes and i used LEDs to indicate witch lamp is being controlled.
It turned out quite usable, downsides is that is doesn’t read values from openhab so if i use sitemaps to dim first then use the encoder it will start at the value the encoder was last used, also it doesn’t dim very smooth. But i can live with that.
Feel free to comment my code but be nice. I am a complete rookie in coding. Most of it is shamelessly copied from various examples I found around the internet.
NodeMCU Code
#include <Encoder.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
Encoder myEnc(D1, D2);
// Update these with values suitable for your network.
const char* ssid = "0ff984";
const char* password = "************";
const char* mqtt_server = "192.168.0.18";
char msgDim[50];
char msgMode[50];
int counter = 1;
int oldCounter = 0;
long oldPosition = -999;
boolean isButtonPressed = false;
long lastUpdateMillis = 0;
//Buttons
int buttonState;
int LED1 = D6;
int LED2 = D7;
int LED3 = D8;
WiFiClient espClient;
PubSubClient client(espClient);
void handleKey() {
isButtonPressed = true;
void setup() {
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
Serial.begin(115200);
Serial.println("Basic Encoder Test:");
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(D3, INPUT_PULLUP);
attachInterrupt(D3, handleKey, RISING);
void setup_wifi() {
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
// Switch on the LED if an 1 was received as first character
if ((char)payload[0] == '1') {
digitalWrite(BUILTIN_LED, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is acive low on the ESP-01)
} else {
digitalWrite(BUILTIN_LED, HIGH); // Turn the LED off by making the voltage HIGH
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266Client")) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("outTopic", "hello world");
// ... and resubscribe
client.subscribe("inTopic");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
long newPosition = myEnc.read();
if (newPosition < 0){
myEnc.write(0);
if (newPosition > 100){
myEnc.write(100);
if (newPosition != oldPosition) {
oldPosition = newPosition;
//Serial.println(newPosition);
snprintf (msgDim, 75, "%ld", newPosition);
client.publish("Lights/Dimmer", msgDim);
// software debounce
if (isButtonPressed && millis() - lastUpdateMillis > 50) {
lastUpdateMillis = millis();
// Up counter on button press
counter = counter + 1;
//Reset count if over max mode number
if(counter == 4) {
counter = 1;
//Change mode
if(counter == 1) {
digitalWrite(LED1, HIGH);
digitalWrite(LED2, LOW);
digitalWrite(LED3, LOW);
else if(counter == 2) {
digitalWrite(LED1, LOW);
digitalWrite(LED2, HIGH);
else if(counter == 3) {
digitalWrite(LED3, HIGH);
if (counter != oldCounter) {
oldCounter = counter;
snprintf (msgMode, 75, "%ld", counter);
client.publish("Lights/Dimmer/Mode", msgMode);
//Serial.println(counter);
Items
/*MQTT Dimmers*/
Number Rotary_Encoder "Rotary Encoder [%.1f]" {mqtt="<[broker:Lights/Dimmer:state:default]",autoupdate="false"}
Number Rotary_Encoder_Mode "Rotary Encoder Mode[%.1f]" {mqtt="<[broker:Lights/Dimmer/Mode:state:default]",autoupdate="false"}
Openhab Rules
rule "Rotary encoder"
Item Rotary_Encoder changed
var LightIntensity1 = Rotary_Encoder.state as Number
if (Rotary_Encoder_Mode.state==1){
sendCommand(Dimmer_Downlight_Stue, LightIntensity1 as Number)
if (Rotary_Encoder_Mode.state==2){
sendCommand(Dimmer_Lampetter, LightIntensity1 as Number)
