Ive got a sprinker that since going to 2.4 it just switches off automatically using the legacy binding. This worked fine before
08:38:06.663 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RearSprinkler' received command ON
08:38:06.663 [DEBUG] [binding.mqtt.internal.MqttItemBinding] - Publishing command ON to cmnd/sprinkler/P
8:38:36.430 [INFO ] [smarthome.event.ItemStateChangedEvent] - UPS_Battery_Runtime changed from 1395 to 1313
08:39:06.789 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'RearSprinkler' received command OFF
08:39:06.789 [DEBUG] [binding.mqtt.internal.MqttItemBinding] - Publishing command OFF to cmnd/sprinkler/POWER
08:39:06.791 [INFO ] [smarthome.event.ItemStateChangedEvent] - RearSprinkler changed from ON to OFF
Binding:
261 │ Active │ 80 │ 1.13.0 │ openHAB MQTT Binding
262 │ Active │ 80 │ 1.13.0 │ openHAB MQTT Transport Bundle
Nothing shows in the Sonoff Console for the device, its just a standard Sonoff on tasmota.
It seems it only stays on for 1 minute. Im thinking this relates to the device constantly checking a connection, potentially it looses connection and switches off. But the Access point is like 50cm away from the Sonoff it self.
My Sonoff is also switching to offline and immediately to online again.
I’ve stumbled upon this issue: https://github.com/arendst/Sonoff-Tasmota/issues/4721
As also written on github i’m not quite sure if updating OH to 2.4 (and thus maybe also updating mosquitto) or updating tasmota caused this.
Yes, it would, it has created it’s own Wifi access point. Connect to it with your phone and go to 192.168.4.1 or 192.168.4.0
And the config of the tasmota should show up to input your wifi settings
Ive found my issue and fixed it. For whatever reason, there was an EXPIRE binding on this item, f knows why. Sorry I feel so stupid. At least I learnt how to restore a sonoff hehe
