I have openHAB running on a PC running mqtt broker. (specs at end of post) I have a Pi4 running openHAB. I have a DHT22 sensor hooked up to the pi and a script sending the data via mqtt to the PC with the broker on it. It works but throws an error every time it runs
I followed this (old but still great) tutorial (thanks @Kees_van_Gelder )
warning: I am a total python noobs!
script that is running can be found here
here is full error
16:22:42.074 [ERROR] [o.moquette.broker.NewNettyMQTTHandler] - Unexpected exception while processing MQTT message. Closing Netty channel. CId=python_pub
java.io.IOException: Connection reset by peer
at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:1.8.0_222]
at sun.nio.ch.SocketDispatcher.read(SocketDispatcher.java:39) ~[?:1.8.0_222]
at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java:223) ~[?:1.8.0_222]
at sun.nio.ch.IOUtil.read(IOUtil.java:192) ~[?:1.8.0_222]
at sun.nio.ch.SocketChannelImpl.read(SocketChannelImpl.java:380) ~[?:1.8.0_222]
at io.netty.buffer.PooledByteBuf.setBytes(PooledByteBuf.java:247) ~[bundleFile:4.1.42.Final]
at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1147) ~[bundleFile:4.1.42.Final]
at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:347) ~[bundleFile:4.1.42.Final]
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:148) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:700) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:635) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:552) [bundleFile:4.1.42.Final]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:514) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.SingleThreadEventExecutor$6.run(SingleThreadEventExecutor.java:1044) [bundleFile:4.1.42.Final]
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) [bundleFile:4.1.42.Final]
at io.netty.util.concurrent.FastThreadLocalRunnable.run(FastThreadLocalRunnable.java:30) [bundleFile:4.1.42.Final]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
here is the script
#!/usr/bin/python
# DHT Sensor Data-logging to MQTT Temperature channel
# Requies a Mosquitto Server Install On the destination.
# Copyright (c) 2014 Adafruit Industries
# Author: Tony DiCola
# MQTT Encahncements: David Cole (2016)
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
import json
import requests
import sys
import time
import datetime
import paho.mqtt.client as mqtt
import Adafruit_DHT
#Usage
#python mqtt.channel.py <temp topic> <humidity topic> <gpio pin> <optional update frequency>
# eg python mqtt.channel.py 'cupboard/temperature1' 'cupboard/humidity1' 4
# will start an instance using 'cupboard/temperature1' as the temperature topic, and using gpio port 4 to talk to a DHT22 sensor
# it will use the default update time of 300 secons.
# Type of sensor, can be Adafruit_DHT.DHT11, Adafruit_DHT.DHT22, or Adafruit_DHT.AM2302.
DHT_TYPE = Adafruit_DHT.DHT22
# Example of sensor connected to Raspberry Pi pin 23
DHT_PIN = sys.argv[3]
# Example of sensor connected to Beaglebone Black pin P8_11
#DHT_PIN = 'P8_11'
if (len(sys.argv) < 2):
raise ValueError('Input arguments of mqtt channel temperature humidity not passed')
MOSQUITTO_HOST = 'servername'
MOSQUITTO_PORT = 1883
MOSQUITTO_TEMP_MSG = str(sys.argv[1]) # Old channel name in here
MOSQUITTO_HUMI_MSG = str(sys.argv[2]) # Old channel name now passed by argument
print('Mosquitto Temp MSG {0}'.format(MOSQUITTO_TEMP_MSG))
print('Mosquitto Humidity MSG {0}'.format(MOSQUITTO_HUMI_MSG))
# How long to wait (in seconds) between measurements.
print "Args length: " + str(len(sys.argv))
FREQUENCY_SECONDS = 300
if (len(sys.argv) > 4):
FREQUENCY_SECONDS = float(sys.argv[4])
print('Logging sensor measurements to {0} every {1} seconds.'.format('MQTT', FREQUENCY_SECONDS))
print('Press Ctrl-C to quit.')
print('Connecting to MQTT on {0}'.format(MOSQUITTO_HOST))
mqttc = mqtt.Client("python_pub")
try:
while True:
# Attempt to get sensor reading.
humidity, temp = Adafruit_DHT.read(DHT_TYPE, DHT_PIN)
# Skip to the next reading if a valid measurement couldn't be taken.
# This might happen if the CPU is under a lot of load and the sensor
# can't be reliably read (timing is critical to read the sensor).
if humidity is None or temp is None:
time.sleep(2)
continue
currentdate = time.strftime('%Y-%m-%d %H:%M:%S')
print('Date Time: {0}'.format(currentdate))
print('Temperature: {0:0.2f} C'.format(temp))
print('Humidity: {0:0.2f} %'.format(humidity))
# Publish to the MQTT channel
try:
mqttc.connect(MOSQUITTO_HOST,MOSQUITTO_PORT);
print 'Updating {0}'.format(MOSQUITTO_TEMP_MSG)
(result1,mid) = mqttc.publish(MOSQUITTO_TEMP_MSG,temp)
print 'Updating {0}'.format(MOSQUITTO_HUMI_MSG)
time.sleep(1)
(result2,mid) = mqttc.publish(MOSQUITTO_HUMI_MSG,humidity)
print 'MQTT Updated result {0} and {1}'.format(result1,result2)
if result1 == 1 or result2 == 1:
raise ValueError('Result for one message was not 0')
mqttc.disconnect()
except Exception,e:
# Error appending data, most likely because credentials are stale.
# Null out the worksheet so a login is performed at the top of the loop.
mqttc.disconnect()
print('Append error, logging in again: ' + str(e))
continue
# Wait 30 seconds before continuing
print('Wrote a message to MQTT broker')
time.sleep(FREQUENCY_SECONDS)
except Exception as e:
print('Error connecting to the moqtt server: {0}'.format(e))
- Platform information:
- Hardware: PC I3 8Gbs 1Tbs h/d
- OS: Mint 19
- Java Runtime Environment: 8
- openHAB version: 2.5.0 M5
thanks for any help
