MQTT-error "No publish flow registered for MqttStatefulPublish"
Platform information:
  • Hardware: Raspi 5, 4 GB (Raspian OS 12)
  • Docker / Portainer: 2.19.5
  • Attached Hardware: Amber Wireless AMB8465 (Wireless M-Bus for water & heat meter), Aeotec Z-Wave Gen5+ (for power meter), SONOFF Zigbee 3.0 USB_Dongle Plus V2 (for various Zigbee devices), HmIP-RFUSB (for RaspberryMatic)
  • openHAB Software: 4.3.3 Release Build, Persistence via InfluxDB
  • openHAB Bindings: Amazon Echo Control, Gardena, Homematic, MQTT, System Info, Yamaha Musiccast, Z-Wave, ZigBee, iRobot
Probably since one of the last openHAB updates my log is flooded with the following message. I know it’s nothing serious, but it’s still pretty annoying. I’m running openHAB and Mosquitto on docker.
2025-04-12 15:29:14.582 [WARN ] [.incoming.MqttIncomingPublishService] - No publish flow registered for MqttStatefulPublish{stateless=MqttPublish{topic=wifistat, payload=67byte, qos=AT_MOST_ONCE, retain=false}, packetIdentifier=-1, dup=false, topicAlias=0, subscriptionIdentifiers=[]}.
2025-04-12 15:29:15.581 [WARN ] [.incoming.MqttIncomingPublishService] - No publish flow registered for MqttStatefulPublish{stateless=MqttPublish{topic=wifistat, payload=67byte, qos=AT_MOST_ONCE, retain=false}, packetIdentifier=-1, dup=false, topicAlias=0, subscriptionIdentifiers=[]}.
I don’t have an item called “wifistat”, and also can’t find anything related to “wifistat” if I monitor my Mosquitto with e.g. MQTT Studio.
This thread suggests restarts (which I’ve done) or Binding-re-installs (which I’m reluctant to do since everything works smoothly).
Does anyone have an idea how I can identify the source?
Update: Not sure if this or this means that it’s a bug?
